My 32 is painted gold (bought like that) and it looks like a good paint job, other than they didn't tape it up very good. (A lot of spray) Whoever looked after the paintwork did a really bad job... If it ever was looked after. I'm using it as my test to cut & polish, but will be going through a couple of YouTube vids so I'm not completely hopeless. I'll chuck some before & after pics WHEN I do the deed. Only doing this because I will be getting a respray in the future.. Still tossing up between a darker gold or white..
Unfortunately this happens a lot where people just take a cut and polish to fix any paint issue and it ends up ruining your paint. Hope all goes well because sometimes a cut and polish is a must and seal with wax. If you get to that stage expect to wax it every 2 weeks or so.
Haha, yeah.. I'm pretty sure I will end up making it look worse :P
But, half of the paint has already been ground away to get rid of the rust :D
The issue with most detailing places is the firs thing they do is take a mild cut and polish to your car. RUINS your paint.
...or I recommend taking the time out and doing it yourself.
My detailer has a "Paint Thickness Gauge" which tells several stories - before even touching the car.
* How much paint he has to work with - or with the N1, not to work with.
* With sun damaged panels (horizontal ones), more latitude can be had with cut 'n polish within certain micron tolerances
* Panels which have been repainted will give off thicker readings
* Nicki (- sounds better than bog) can be detected in vulnerable spots
If you don't mind giving a ballpark figure, how much does it cost for someone to give the car that much attention to detail etc? Just curious really.
Eugene Chan charged me $400 (mates rates) for the two day weekend Jeremy.
Typical process was...
Wash > Clay Bar using Lubricant > Polish (Menzerna brand) 2x with different grade pads > Sealant (Optima brand) applied > Cure overnight > Wax (Meguiar's or Menzerna brand) > Buff
Eugene (aka JDM_Performance here on SAU) learned from Polich Doc in Melbourne. Eugene detailed my 3x R34 GT-Rs
#1 R34 GT-R Black won the Concours Skaife award at the R34 GT-R 10th Anniv
#2 R34 GT-R Bayside Blue (above) wasn't owned for very long before being forced to choose, upon the availability of an N1 - paint thickness on every panel was about 320 microns
#3 R34 GT-R White N1 in PI Magazine #161 - paint thickness on every panel was consistently about 90 microns
Yup, very happy with Eugene - but pretty far away from you guys I'm afraid.
  • Like 1
Yes it's impressive.
It won't work unless the panel is made of metal.
C/F, Nicki or rust with give lousy readings.
The Detailer has to love what he does - with a passion!
Eugene has that passion - yet he hates gardening.
I love gardening - but but hate detailing unless I'm totally in the mood and begin by 7am , Lol
Thanks for the info Terry. Amazing job done on an amazing car. It's almost worth driving down to Sydney and then glad wrapping it for the trip home haha :P
If you let him detail your N1, then Eugene must be good.
Cheers for sharing.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
