Love my RB30/26, would never go back to having the 2.6
Makes heaps more torque at a much lower rev range, and it doesn't need to be revved to death to make power.
.....car should have come with it already in here.....
To do the complete oil fix properly it's a head off job anyway. One of the best things you can do is improve the head oil returns to the sump. I reckon I took about 10mm out of my head around each of the 2 main holes, they're so much smaller than the galleries in the block.. Nissan really did do a shit job at the factory of finishing off the head.
Yeh I realise this... What I'm thinking I mite do is: I'm on a good thing with a very reasonably priced fully built 30/26. I'll buy this engine and keep my 26 and do the oil mods and have it as a spare... If the 30/26 lasts say 10,000km I'll deem the build reliable and then I mite think of selling the 26?
Yeh I realise that. My thinking is: the 26 is stock so you know it is put together perfectly at Nissan with the added piece of mind I have already tried and tested it. The 30 has been built by a shop and all it takes is one small thing to go wrong and bang...
I agree. My car has been off the road for 12 months now building my 30. Leave the 26 in until the 30 is ready to bang in. I did the same as what you're proposing- buying a built 30 assuming I could whack it straight in and away I go. Mine was a lump of shit and I had to start completely from scratch. Don't waste your time unless you're 100% on the engine you're buying. If you don't have a young family and other committments then you'll bowl it over a lot quicker than what I will!
I have a 30 block and a 26 head for sale if your interested mate.
I would have built it but other things come up and my 26 doesnt show any signs of letting go anytime soon.
PM if your interested.
Hmmmm ok. Anyone here that has had both and can explain why it will be that much better apart from the moderate power gain?
have had both.
for street, go the 30, alot nicer to drive due to better low end.
for track, keep the 26 until it pops, the replace with a built 26.
alot easier to swap in/out if anything happens as everything just bolts up.
where abouts are you located?
response and power out of corners come down to turbo selection.
see if you can go for a ride in someones car that has the conversion.
was going to offer, but its a little far for you to travel.
Honestly, if it's 90% track you don't need anymore power. As previously said put some forgies and rods, balance it up, get the oil control sorted and your done. Spend the rest on chassis and suspension setup. 370 is more than enough. Also a revving 26 sounds much nicer than a stroker or a 26/30. Whoops did I say that....sorry.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
