Hi guys,
My r33 gtst has recently started intermittently overheating.
It is completely random. Sometimes, it can drive for days being fine whilst other times it will overheat immediately.
when it does start to overheat I can stop the car, let it cool down and then its fine to go again without overheating.
Only appears to lose water when it overheats and comes out the reserve.
I've tried another thermostat..... still the same. Any ideas?
https://www.sau.com.au/forums/topic/433670-r33-overheating/
Never had this problem myself in a skyline, but my run around (shitbox) honda integra used to have that problem - turns out there was an electrical issue in which the fan would randomly (& intermittently) stop working.
Good luck with it :)
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7071727
Is it just random, even at low speed?
Do you still have the original radiator?
It is getting old so I'd say replace the radiator.
Mine would start to overheat when driven at 100km/hr. Went through the steps and once radiator was replaced all good.
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7071838
Thanks for the replies!
So far:
New Thermostat hasnt changed anything
New radiator cap hasnt changed anything
The electrical fan appears to be working
Not the original Radiator - It got replaced a few years ago
I happens randomly so Its got me stumped :(
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7072130
thanks for the replies.
All work done professionally by a mechanic (not me!) so quite a few things checked.
Thermostat is genuine Nissan.
All (or if not most!!) hoses have been replaced
Yes still has the standard clutch fan
I've never done a water pump in it
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7072396
O.K. How many km has the engine done?
Highly doubt its the water pump, especially if the teltale isnt leaking but have to ask anyway
Does it need coolant ever?
Have you measured the temperature with a temp gun or something like that? Just in case the sensor is a bit funny and giving false readings
Edited by 89CAL
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7073160
Not to hijack the thread, but I've had overheating issues lately too..
When I'm on the move, the car is fine, but when I'm stopped, that's when it can overheat (and the temp jumps up pretty quickly)... And it happens randomly too!!
Found a whole lot of shit in the radiator fluid and overflow bottle, so I had the radiator completely flushed and the fluid replaced... Any thoughts??
I'm thinking maybe water pump, hoses or fan.. Anyone have any similar issues that can give some advise/insight??
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7075630
If its overheating when its stopped and not overheating when its moving, then wouldnt the logical problem be the radiator fan? Seen as you have had the radiator serviced this is pretty much all it can be. The fan doesnt do alot when the car is moving, when the car is stopped the airflow accross the radiator is created by the fan
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7075643
Yeh I know, and that's what I thought.. When I took it to my mechanic a second time to check it out with me, it was fine.. One of those "does it when no one is around, and doesn't do it when u want it to" kind of things...
Just thought I'd post up incase it could be something else.. Probably best thing is to just sort out the fan regardless..?
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7080439
Well if you haven't done the radiator in recent years take it out and get the top taken off and either clean it out or get a new one if necessary. If its getting blocked it will still work better with a 100km breeze going through it than when stationary.
https://www.sau.com.au/forums/topic/433670-r33-overheating/#findComment-7080574
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
