Hi,
About to finally put my 2835 pro s turbo kit on my r33.
I thought the 255lph walbro pump I have now might be at its limits? So looking for the next easiest fuel pump upgrade for it?
Looking at the following options:
Bosch 040 clamped to the original cradle
Bosch 044 mounted in tank with a male screw in fitting and modified sock - post-15190-0-85766800-1382582511_thumb.jpg
Walbro 460 lph pump - http://www.skylinesaustralia.com/forums/topic/410989-all-new-walbro-460lph-e85-in-tank-fuel-pump-strainer-kit/
We all know working on r33 pumps is a massive PITA, so I dont wana over complicate things, just pull the current setup out, rig up something easy and drop it back in.
Thanks in advance,
Matty
Best/Easiest is a Nismo/Tomei/HKS pump (all the same pump, Tomei is usually the cheapest)
But this is pricier then a new Walbro. You were asking for the Best/Easiest though so thought price might not have been such an issue
Do that, and maybe do the direct feed re-wire if you want to make sure its getting full power all the time
255 should be fine, but as i found out years ago... Sometimes they are not, even a few months old, if you are running a bit of boost as the Walbro simply don't perform when higher rail pressures are asked of them where the Bosch/Nismo etc kick goals.
So either take the try and see approach OR - Do what 89CAL said, right on the money as always.
my tomei pump didn't like it at all when I put 6 bar fuel pressure through it...
87psi......
Why that much? :S
My Tomei pump has been perfect for the last 4-5 years. Isnt loud, does the job, and has never played up. Great pump :)
Nothing against any others, I havent used them so I wont comment for or against. But the Tomei pump comes with everything, in a cradle, ready to slide in.
Edited by 89CAL
wasn't intentional......but it made a lot of ugly noises when it did...
87psi......
Why that much? :S
Get the bigger Walbro or equivalent Deatschwerks or if you want Japanese I think the Denso is the same pump as Nismo/Tomei/HKS but cheaper. Anything but a Bosch 044 - I've got one in a steel case insulated inside and outside and its still far too noisy!
For $200 you really can't go past the e85 Walbro. They are nearly silent when installed correctly and flow massive amounts of fuel. The petrol version is only $150 or so, but why limit yourself to dino fuel...
Thanks for all the info,
r31 nismo has me a little paranoid about my current pump now, plus it was second hand when I put it in.
I'm going to go with the 460lph walbro, looks like an easy swap over and reasonably priced.
