I found a whole heap of Rx-2 Coupe parts under the house. This is of course useless at a Skylines Car Boot Sale. Which means I will just end up buying stuff. Unless I can sell home brew beers?
Edit: actually I do have some R32 GTR shit. Let's go!
You'd be surprised regarding RX2 stuff.
I'd be up for this too Terry :)
I asked the Exec to discuss n implement last Fri at the Exec Meeting. I assume it was on the agenda as requested Corinne. I'm yet to see the minutes n outcome. Let's hope...
(I couldn't make the meeting due to...)
  • 2 months later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
