ok, wanted to finish the car and drive it a little before I threw this up.
have been driving for 1700kms now, with no real adverse affects**
so, welcome all to my 30mm subframe drop thread.
any questions you have, throw them in here, and I will try and answer as quickly and honestly as possible.
please keep in mind, I doubt this is legal.
these havnt been "engineered" yet.
I will try one day, but havnt had the time/money associated to do so.
I will try and include any info I can that helped/hindered myself when doing this.
the spacers I used were made by a race/rally car engineer, and calculated that the stud the mount to would snap before the shank nut.
so, here we go....
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/
1st, why did I want to space?
easy, I didn't want to cut my bonnet.
for that one, simple reason I undertook this task.
now, as many know, you don't have to cut bonnets in a 33/34, but 32s, its pretty much the only option.
some other advantages:
-if done right, exhaust should line up to near factory*.
-turbo to guard pipe should line up*.
-guard to plenum should line up*.
-looks more factory(to a degree), as the motor is still roughly the same spacing from and strut bars.
some disadvantages:
-cooling fan no longer lines up.
-slight slope to motor.
-cant lower car**.
*should has been used, as I went with a single turbo conversion, so am unsure of pipework.
I also changed to a Greddy plenum ive had on the shelf for years, waiting for the build.
**cant/shouldn't lower the car more, as due to the engine being lower, the cvs are at a lower angle already.
so, in essence, dropping the subframe 30mm, is like lowering the car the same amount.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096833
2nd, why not lower the engine on the mounts and run no cam cover, or cut bonnet bracing?
I have lowered the engine in the mounts(die grinded mount holes).
I wanted the cam cover for the fact it keeps debris out, and less attention.
And as stated, I DIDNT want to cut the bonnet in any way.
everything I have done can be reversed.
all can be put back to standard.
that's the way I wanted it.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096835
now, for process and pics.
first, the spacers themselves...
the spacer was made in 3 parts, 20mm, 5mm, 5mm totalling 30mm all up.
the reason for this was so, if the whole 30 was not needed, the height could be adjusted.
height can be 30, 25, 20, 10 and 5mm(just swapping the pieces around.
the top spacer is actually the washer for the nut.
a shank style nut was used so it would have the greatest thread contact area, whilst also locating the spacers themselves.
the extra height on the nut is just under the thickness of the subframe itself.
and all done in the box when picked up.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096856
Lower the engine? The spacer plate to convert the 2wd block to 4wd already brings the sump a CM closer to the subframe stuffing up that idea.
I think the way you did it is the best way, the more i think about it the more logical it becomes.
The best part is if running a heavy clutch, you can still use the factory booster, im not a big fan of building the left leg, prefer to build the center one instead. :P
Come on man, get some pics happening. :)
Edit, you just put them up as i posted. LOL
Edited by GTRPSI
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096858
during the install, had to lower the whole subframe evenly.
then, enlarge the holes for the shank nut.
I used a stepped drill bit.
worked very well to get to thhe size needed.
also went a little oversize as the original holes were bigger, and allowed for any differences.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096873
ok, so now installed.
keep in mind, the factory uses pinch nuts to lock them.
USE LOCTITE!!!
you don't want a subframe coming loose.
also, the steering column required extra length.
this was a temporary solution to push the car in and out.
was thinking about it for use, but the torque put on those bolts would eventually snap them.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096878
FINALY......
I do have a driveline vibration.
thoughts were it was from the tailshaft angle.
so, I used spacers and extended bolts to space the gearbox crossmember down, and the centre bearing down.
its only under power.
more noticeable in 3rd.
cant be felt at cruising speeds or loads.
could be in gearbox, as ive got a new gearbox in the car.
could also be tyres, as they literally sat in the one spot for 8 months, ad have flatspotted.
either way, id recommend spacing the gearbox xmember and centre bearing carrier.
also, the lines on the hicas pump/valve will give the 30mm needed.
so will the steer return lines.
as stated, you can no longer use the factory fan.
electric thermo fans will be required.
hope you all enjoyed the read.
again, post any questions, and ill try and answer them.
if in the Sydney area, come to one of the runs and have a look.
thanks for reading.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096968
Luke that is one filthy engine bay! Get some degreaser on that shit!
Good work though, nice write up and good piccies!
thanks mate.
and why bother cleaning the bay when its going to get dirty again? :P
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7096999
Very good thread Luke, great work, should be made a sticky.
There are a few forums on the web that talk about using a single 10mm spacer, but using a 30mm one only leaves the top 8mm higher than factory, more than enough room to close the bonnet and some more for spare.
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7097091
dont forget I elongated the engine mount holes, so should be same height now.
even with that, and the sump adapter, I have clearance between the sump and X member
https://www.sau.com.au/forums/topic/434617-spacers-you-bet/#findComment-7097669
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
