Will the drive shafts actually only be 20mm angle than a 26 because the sump spacer puts them 10mm lower in centre to start with?
no, due to the 10mm sump spacer, the the 30mm subframe spacers, it ends up being 40mm total.
Could you use longer bolts through the chassis rail to go through the longer nuts if you were that anal?
theres no real access to the chassis rail internals.
and the factory set up uses studs.
so, youd have to punch those out, then install bolts some how.
I had thought of this, but it seemed the harder option.
pity the car's rollcentre and handling is now up shit creek all because of a bonnet that you didnt want to cut
I havnt noticed any discernable difference.
and it wouldnt be any worse then lowering it.
lowering your car lowers the roll centre, so does dropping the subframe. if you maintained the stock rideheight it would be fine but lowered car + dropped subframe = SHITHOUSE roll centre
I have maintained the stock ride height.
since purchase ive raised the car 4 times.
  • 3 months later...
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
