Hey guys. Ive done pretty much all I can to my R33 GTST. as far as bolt on mods go. Its currently putting down 250rwkw. Doin the last little job next weekend and then I gotta retune it. Pretty sure ive gone as far as I can with standard internals. Im expecting around the 270kw mark after I retune it. Is there any other uselful mods u guys can advise me to do, not for power gains, but just to make it run a bit better? (help the thing live for as long as it possibly can). I dunno if io posted this in the right place, but im open to suggestions anyways. Thanks guys
https://www.sau.com.au/forums/topic/435064-what-else-can-i-do-to-my-rb25/
My tuner advised me to replace the exhaust housing my hi flowed one. He rekons most hi flows should get about 250rwkw, but with the GCG the standard exhaust housing is a lil restrictive. I got another for it. Im gonna replace that and retune it. He rekons hes tuned cars that got 290atw from that turbo, so I went that option for now just coz its cheaper and easy
E85 is about the only thing to make it last longer.
Imo 250 is prefect for the street, why not just leave it and enjoy it? Since my car started making 260kw I've actually gone "you know what? this is more than enough power for the street" The turbo comes on like the stock one but makes 260kw with no lag, what more could you want?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
