How did I misspell your name beyotch? your nick was skyzerr back then wasn't it?
there was a couple of days where the forums went offline... I blamed you guys for pissing em off, just as I was about to buy my first Skyline :( that's what i meant by shut down
Skylines Australia is born...
http://www.skylinesaustralia.com/forums/sh...thread.php?t=77
Post Number 22 is where the term Skylines Australia is first used.
Quickly followed by SDU-AU, SOZ (man who thought of that one?), SPranK (PranK's early hints at a dictatorship) and NSA (which still sounds like a cool FBI style name).
OI! Post number 21, thanks very much!! By me!! :boobies2:
I agree SDU went down hill something chronic when it got to political (hence why im not a member anymore) SAU forums seem to be more "on topic" and "knowledgeable".
Just to add im sure there is a few ppl around here from the old ezboard days many years ago (5?) the original birthplace of both forums :)
I think we need a reminder of our friend Mines_Datsun...  of course it was before my time here, but the way you guys carry on, i think he deserves a honorable mention, and give us a reminder of his sheer stupidity! thanks for taking the time to write this up funky
I second that...the original thread was deleted though :D
I joined in August 02, generally keep a low profile
  • 3 weeks later...
Things have changed even in the time I have joined, which isn't a massive amount of time really.
Seems the forums are getting a lot "younger" and the intelligence is dropping a little ;)
Don't think you would have got many of the types of threads you now get a couple of years back..
  • 1 month later...
interesting... especially digging up those old threads... i thought most of them was gone since the last server maintenance or something...
I thought by longitute/latitude nz is located closer to the south pole than tasmania? so that makes them really downunder?
i'm not old skool enuf? or cos i just dun postwhore enuf in wasteland?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
