I am in the market for a new ecu for a 2j motor.
Noticed haltech have a new ecu coming out towards early next year but unsure if I can be bothered waiting for it.
I have noticed ViPEC have a new i88 ecu which looks quite good.
Anyone have any feedback on this particular ECU ?
https://www.sau.com.au/forums/topic/435341-new-vi-pec-i88-ecu/
Vipec is basically a Link and i have been running Links for years.
Awesome ECU. Numerous motorsport options which are all unlocked, they only require a small cost motor sport harness be purchased, options of up to a 7 bar map sensor, runs well with the Ross Balancers crank trigger system
I see no reason to not use one ;)
Does this new Vipec have built in Knock sensing capabilities?
I heard they might be coming out with this a while ago, would be the only benefit over my link G4 that I have at the moment.
Although link have realeased G4+ (Not in plug-in version yet from what I've seen) so it might end up being a similar thing
Apparently, unsure how good or how different it is from the previous model.
http://www.vi-pec.com/ecus/i88
ndividual Cylinder Knock control, with support for two sensors. Knock control is user definable with flexible settings to allow precise knock control adjustable by ignition angle
Yeah that is literally the only thing I dont like about the G4 is that there is no onboard knock sensing.
But I suppose it wont be hard to update in the future. Hopefully it can use the stock knock sensors. I kept these on the engine even though the Link doesnt support them, in the off chance that they would work later on
E85 - built in knock sensor :D
another happy G4 customer - first flex fuel conversion, first non-HKS electronics V-Cam control - pretty stout piece of kit :)
can't go wrong with the link/vipec's
G4 is brilliant, just depends on how many items you want to run off it. Flex fuel, crank trigger, wide band, oil pressure, fuel pressure... You run out of inputs very quickly.
I used to run a vipec. trying to sell it and upgrade to a haltech. Better tech/product support.... that and there's only 1 vipec dealer out here lol and his tunes take me into the 10 and 9.8 AFRs...
Edited by NismoSTune
So a couple of features on this ecu that makes it a little more favorable to the haltech is the knock control and 4 temp sensor (have to add resistors to the haltech!).
However, mapping is a bit better on the haltech and i know i am able to change a voltage setting for the tacho output...
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
