Seven-time Formula 1 world champion Michael Schumacher is in hospital after suffering a head injury in a skiing accident.
The 44-year-old fell while skiing on unmarked slopes in the French Alps and hit his head on a rock.
He was attended to within minutes of the accident before being airlifted to Moutiers hospital.
Despite initial reports suggesting his injuries were serious it is believed that Schumacher, who was wearing a helmet, is not in a serious condition.
According to the Press Association, Gernignon Christophe Lecomte - director of the Meribel resort in which Schumacher was staying – told Radio Monte Carlo Sport that the ex-Ferrari and Mercedes racer was conscious, and was airlifted with 15 minutes of the accident.
The German's manager Sabine Kehm confirmed nobody else was involved in the fall, and was also quoted as saying: "Michael fell on his head when he was on a private skiing trip in the French Alps. He was taken to hospital and is receiving professional medical attention.
"We ask for understanding that we cannot give out continuous information about his health."
http://www.autosport.com/news/report.php/id/111978
'Tis likely that "Schu" will remain in a "permanent vegetative state" unless...
Dat penises nose though
The Chin could live with the step but buggered if he was driving a penis nose.
I've only ever seen a sketch of one bloke's interpretation (ie 'guess') of what the 2014 cars would look like that suggest they'll have a 'penis nose'. All the other guesses have been very different. I'd be willing to bet scarb's is miles off when the cars get unveilled.
Force India looks good. Can't see the nose yet though...
Last I heard before the family closed off communications with the outside world was he was still in a coma. Vegetative state is a different clinical state. "Permanent vegetative state" is certainly not what anyone has called it, because they don't use that term until the patient has been that way for about 1yr...
The truth of the situation isn't terribly optimistic, but spreading completely incorrect information is not helpful. This is about the best quality information (well speculation) we have since the family shut off communication to his many anxious fans:
http://formerf1doc.wordpress.com/2014/01/22/what-may-be-going-on-now-and-where-this-might-be-going-long-speculative-and-detailed/
for those that haven't seen check this out for a bit of detail about the engines for this year.
http://jalopnik.com/how-formula-ones-amazing-new-hybrid-turbo-engine-works-1506450399?utm_campaign=socialflow_jalopnik_facebook&utm_source=jalopnik_facebook&utm_medium=socialflow
is it just me or do these newest lot of regs spoil what could have been some incredible engineering?
They should just make it a regulation that the very tip of the nose cone had to be wider and it wouldn't look so bad? Eg tip of nose width must be 'X' mm wide or '85-90'% of the width 300mm from tip
Edited by Scottydoo
Formula 1 is to make another attempt to ban tyre warmers in 2015.
Previous efforts to introduce a ban have been scuppered because of safety concerns, amid worries from drivers about racing on cold tyres.
But as part of a raft of changes proposed for 2015, the FIA announced on Thursday that all forms of tyre heating devices will be outlawed.
The FIA has also ratified that the minimum weight of cars will increase by 10kg to 701kg in 2015 - which should help alleviate concerns that heavier drivers are put at a disadvantage.
http://www.autosport.com/news/report.php/id/112250
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
