Much better!
But that reminds me I need to order a leave me alone I know what I'm doing t shirt before Melbourne.
They don't sound as terrible now that they're pushing a bit harder, still not F1 though
Just wait till the season starts. None of the drivers will use more than 70% throttle because they'll be too busy saving fuel.
I want to look forward to it, but I can't shake the feeling that Bernie has bent this formula over and is giving it the no-lube cavity search for cash. It's f**ked. Gimmick ideas like DRS to "make a better show" - gay. No refuelling on "safety" grounds yet the lack of fuel load as a strategy variable means everyone just tries to ration it. Tyres that deliberately go off and have a narrow operating window means everyone rations this too. Can't drive too hard - can't afford the fuel bill or to have the tyres go off.
JAS-25T you better upload that 2004 vid before I slit my wrists, this season is depressing and it hasn't even started yet :P
Just over 2 weeks until Melbourne...
Watching them cruise around slowly, conserving fuel, is going to be hard going.
Practice 1,2,3 at turn 1-2 will be the highlight IMO the rest is shaping up like a solar car challenge.
I cruise around slowly conserving fuel for work, and i gotta tell ya... it blows
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
