A race for third place tonight, it will be a coin toss for Hamo and Barbie for the top two steps of the podium.
A shame for Dan to get the last of the three part penalty from the unsafe release hopefully he can cut thru some traffic although he might be fighting for position with The Hulk and Bieber.
So all those guys were hanging sh1t on Dan and RBR for picking a clear No.2 vs Kimi? Dan is showing a lot of class for a young guy with pressure on him. Has not put a step wrong in first 3 races
Well he has done well to out qualify ze German twice in three rounds and given the way he went wheel to wheel with everyone in Malaysia the signs are looking very promising indeed. Is it to early to urge RedBull to put all their resources behind Dan for the rest of the year and get his team mate to do the support act thing?
Adrian Sutil will start from the back of the Bahrain Grand Prix grid after being hit with a penalty for impeding Romain Grosjean during Formula 1 qualifying.
Lotus driver Grosjean was coming up to the Sauber when Sutil moved to the right and forced the Frenchman to brake in order to avoid contact.
Race stewards said Sutil had "forced car 8 off the track between turns 13 and 14 in an unsafe manner" and imposed a five-place grid penalty.
Sutil, who had qualified in 18th position, will now start from the back of the grid.
The Sauber driver was also awarded two penalty points for the incident.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
