I wouldn't say that dan had a small window when it came to passing perez. He was stuck behind him for ages after the last pit stop. For a few laps it looked like he had more chance to get overtaken by Vettel more than get passed perez. Had Dan been able to get passed sooner then Vettel would've gotten second instead of third. I was actually kind of cheering Vettel on for once in that race (after Dan).
It would've been nice to see Mercedes being beaten in full on racing rather than just limping around for the second half of the race waiting (and waiting and waiting) for the rest to catch up and pass them.
Yeah it is rather depressing that mercedes had such a disadvantage for near half the race and Dan still only just beat them. Albeit Perez held them up an awful lot, its still quite impressive how fast that mercedes must be around those corners as well as the straights (when the power unit is working)
lets hope its a trophy fitting of such a great man, and not one of those silly looking cat dishes
The trophies (Or the first place one) are, if memory serves, based on the steering wheel in one of the Coopers Brabham drove. Youll see the thin wooden trim around the outside. Not sure if the diameter is right but it may be.
So they are atleast ok in their inspiration if maybe not so much in their execution. Still there are plenty of more shit ones at the various races.
There doesnt appear to be any numbers for the race but looking at the trap speeds in quali:
Pos No Driver Time of Day Speed
1 11 Sergio Perez 13:05:19 337.7
2 19 Felipe Massa 13:28:15 337.5
3 77 Valtteri Bottas 13:27:53 335.6
4 44 Lewis Hamilton 13:53:28 334.0
5 6 Nico Rosberg 13:05:40 333.6
6 27 Nico Hulkenberg 13:27:50 333.4
7 26 Daniil Kvyat 13:30:55 332.0
8 25 Jean-Eric Vergne 13:31:08 331.7
9 20 Kevin Magnussen 13:05:49 331.5
10 22 Jenson Button 13:06:47 330.3
11 4 Max Chilton 13:06:41 328.7
12 7 Kimi Räikkönen 13:29:55 328.4
13 8 Romain Grosjean 13:31:25 328.3
14 14 Fernando Alonso 13:29:58 327.7
15 99 Adrian Sutil 13:05:31 326.4
16 3 Daniel Ricciardo 14:00:20 326.4
17 17 Jules Bianchi 13:08:37 325.9
18 1 Sebastian Vettel 13:31:04 325.1
19 9 Marcus Ericsson 13:04:50 323.5
20 10 Kamui Kobayashi 13:08:01 322.7
21 13 Pastor Maldonado 13:05:01 321.2
Yet again the RedBulls were near on the slowest and anything with MB power was up the front. Chico fastest of all. The DRS can only do so much. Dan only got past Perez when he started to have brake problems which meant he only had a small window to get it done and get after Britney. Had he not got either move done when he did it would have been p2 at best.
Edited by djr81
  • Like 1
Well it is generally regarded as being a Renault issue more so than a RedBull issue. So I am going to go with no. That is based on the restrictions placed on the engine manufacturers as much as anything. Hoping Renault get their sh!t together for 2015. And Honda too, come to that.
RBR Mercedes, Dan world champion. :P
STR's are still Renault arent they? they are by far the 'fastest' Renault powered cars, but they didnt have the best run in Canada so maybe it was all down to a lower downforce setup
To me it looks a bit 50/50. But honestly Massa had plenty of room, Perez was entitled to have a look up the inside of Vettel. Both turned towards each other a bit but to me Massa turned in harder
yeah, the racing line... you are not allowed to change your line when someone has an overlap, that's the rule! Even if it just their front wing that overlaps. In this case is was wheel to wheel contact.
Perez does not have any entitlement to look up the inside of Vettel if there is another car already beside him - which clearly there was.
You can't go around swerving at a guy who has an overlap in a 300kph braking zone.
Bu tthat's not what Vettel was doing anyway - Vettel was 2.5-3 car lengths up the road and Perez was nursing rear brakes at the time!
Edited by hrd-hr30
So, my question is, does red bull have the tech (and money) to be able to get backup to mercedes speed prior to the end of the season? or will that tech be copied in the off season in time for next year?
They have the money, yes, but given that no performance changes are allowed to be made to the engines, only "reliability" changes. So we won't see changes to their pace till next season. Even then they can't make massive changes.
As for rbr vs str, I'd say that aero package and chassis, and possibly even gear ratios, are the reason for the speed difference.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
