3.5L runs a different plug, and has different CAN protocols. The 2.5dd, 3.0dd and 2.5det all run the same ecu plug with slightly different pinouts.
Most 3.5L ecu's will work, without cam actuation. If you want the cams to work, you will need to reprogram the frequency/degree and self learning, which only the Haltech Elite can do afaik, and without Haltech support you are up the creek (as Mercury found out the hard way). Short story- Don't bother at this time.
  • Like 1
  • 4 weeks later...
Hi... I'm Rick and I'm new to the stagea forums... I have a a m35 arx and.am about to start modifying it... As for ecu options I have read all the covered options and decided to do some searching of my own... The only other option I found other then what has been covered is something called UP REV OSIRIS TUNER... I believe rev zone are the dealers in melbourne for this. I have spoken to them and they want to see my car and plug in a diagnostic to see if they can licence the ecu... Anyone been down this path???
The only ecu options available and proven is the Emanage piggyback, or the HDI Maxrom afm signal bender. (unless you can find a discontinued VQ25det specific loom for the HKS Fcon Vpro. This is by far the best option, and the most expensive)
The Adaptronic has issues, as does any other standalone at this stage. Personally it's hard to go past the Emanage Ultimate in Melbourne at least, as there is a tuner here willing to touch it.
The Osirus dongle can't read our map, it just comes up as jibberish, corrupt data, as ours isn't the same OBD2 protocol as they are used to dealing with. We tried this path years ago and nothing has changed to my knowledge.
What are your power goals? I can suggest the best option for you that way.
  • Like 1
  • 3 weeks later...
Just translated it..
For that price you may as well just get an emanage..
Description of item It becomes NISMO computer.
Dirt.
It is not failure of the coupler.
There is no problem with the mounting portion.
Data is unknown.
Seal is not affixed to the full.
Operation verification ending.
There are a small wound. Detailed condition, please refer to the image.
Edited by Reaperblitz
Dirt.
Data is unknown.
The nismo is something you want to use combined with the emanage. It fixes a few issues the emanage can't. Speed limiter and throttle issues etc
80000YEN is not good deal for nismo ecu, it could get an e-manage with tuned around 1300AUD
I don't think you fully understand just how different a Nismo ECU is, compared to a stock one.
I am also using aftermarket ecu right now. I just want to say the low value compare with the high price. I was not saying nismo ecu equal to emanage.
i would agree with this, i don't think its worth the price
If it was it would be sold already.
Interesting that the emanage is still the most capable ecu on the market at the moment, and the only things it doesn't get rid of is the Speed and rev cut. If those worry you, then any way around them will be expensive.
180 km/h limit ?
Damn, I was looking forward to testing my stock brakes and suspension at 200 +
you can buy HKS SLD (speed limit defencer) to unlock 180km/h if you can't find cheap aftermarket M35 ECU.
Agreed, mine works well, but understand you are cutting the main CAN communication lines to install it.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
