so i got a R32 GTS and well as you can expect from a N/A RB20 its rather sluggish. ive got a turbo motor that i bought, it came with the intake, turbo, dump pipe, ECU and oil lines.
the plan is to clean the turbo motor up and swap the good bits from the na block and transfer to the turbo block.
i have a few questions on thing im not clear with:
1. where do i put the AFM
2. is there any other sensors other than the AFM, O2, CAS, TPS that the GTSt has that the GTS has such as pressure sensor etc.
3. do i need a bigger fuel pump and pressure reg
possibly many more questions coming
thanx guys
https://www.sau.com.au/forums/topic/436198-gts-to-gtst-conversion/
Cheaper to buy a gtst than convert a gts
You have the engine but it seems you havnt considered the brakes and the many other little things you need to make this a sucessfull conversion
Ok here is a step by step guide I wrote up a while ago:
1. Put your car on carsales.com.au
2. Sell your car
3. Buy a GTS-T
4. Go on a $4k holiday overseas with the money you saved
5. Proceed to drive your GTS-T which is worth more, less expensive and better than a GTS +T
  • Like 1
From memory, it goes under / behind the airbox.
So: Airbox > AFM > Intake Pipe > Turbo
This!
oh yeah, did them and the hubs already
mostly just want the engine stuff, not bothered about everything else
Considering your car will have more power then the N/A engine, there will be things that need replacing in order to handle the power upgrade.
You'd want to look out for the clutch.
A brake caliper upgrade to the GTS-T model would be a good start.
At least a 3" turbo back exhaust will help with the exhaust flow.
Did the RB20DET you bought come with the side mount intercooler and blow off valve?
It's just a start to the "To Do List" for this conversion.
I may be missing something, but if you have a turbo motor sitting there, why not jut put that in?
Sounds easier then changing bits over, not to mention the comp ratio will be right on the turbo motor
If the turbo engine is blown then disregard this :)
Okay, so I have the hubs, rotors and calliper a from a GTS t, along with the ecu and motor from one
In regard to the AFM, I have a custom intercooler, now do I put it after the intercooler in regards to pressure drop across the intercooler or am I seriously wrong
The bits I'm swapping is just vacuum lines, alt, power steer pump etc
Exhuast will be custom made, got a HD clutch waiting to go in and haven't got a BOV as I told I didn't need one as it will only ever run 7-12 psi
Air flow meter measures air flow (hence the name) so pressure makes no difference, a good example is you get a cylinder of compressed air, you blow up a massive air balloon with it, the baloon takes up an entire room at atmospheric pressure vs the cylinder taking up a small space with extremely high pressure, is there more air in the cylinder? Answer is no hence assuming the pressure drop from the IC isn't due to a leak you still have the same amount of air.
If it was a MAP (pressure) sensor, then yes it would matter as it doesn't measure airflow, it just infers airflow from pressure.
Edited by Rolls
will bov or recirc valve increase perfromance and stop damage in any way
also do i need a GTS-t fuel pump or will and GTS one suffice
Not sure if they are different or not, I would get a replacement for peace of mind though.
BOV won't do anything for performance or damage, purely to keep noise levels down and stop popping/richness on gear changes.
well the cars off the road for a while so ill try the GTS one for a while and see how it goes
okay no worries
If it doesn't work it might still run but just lean and blow your motor up. Only way to know if it is working is with a wideband in the exhaust, a dyno shop could check it for you, wouldn't cost much more to just buy a new pump though.
I wouldn't run an RB20DET with the original factory turbo fuel pump. They're so old now that they're just waiting to die. On that basis, using the original NA pump would only be as bad, if not worse.
Bite the bullet, put in the $200 Walbro now and be done with it. Save yourself the headkicking you'd have to give yourself if you don't change it and it fails.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
