It looks as if there'll be several polar white and several bayside blue BNR34s rocking up Bobby.
Can you ask your photographer to stagger cars of the same colour so that they're not juxtaposed?
That'll help each car to be highlighted on its own merits - my 2c
No spectators they will be asked to leave .!we are organizing security for the night .terry need to speak to you about this.
Lowdown will be covering all the photo shoot .
Once we greet each other I think it will be a good idea to see and speak about each car .
Again this is only for r34 gtr owners and if they bring passengers that's fine 8)
got no problem with the idea of a 34 only meet, good luck to you, pics should be great.
But did I read right that you're hiring security to tell people to not look at your cars that you have chosen to park in a public carpark?
what if I buy a 34R from someone that is already at the meet, and I need to pick it up? can I came in an inferior car and then burn it at the gate and drive my 34R home? or do I have to organise a ride in a 34 R?
No this would be strictly against the rules. They are going to have security at this event to prevent this type of thing. You would have to buy another R34 GTR, say a week before hand, drive to the meet, supply 100 points of ID, rego papers, receipt for purchase of the car etc. You would then pick up the second R34 and then leave. You would then need to check what restrictions are in place after the event with the organisers in terms of disposing of one or both GTRs.
Just do it how they did for the R32 21st cruise etc.
for the cruise parts they broke everyone up by model of car, but everyone was quite well mannered and to put it bluntly, not a bunch of elitist assholes.
That's what I proposed to Bobby 8 days ago Matt; the fact that you, me and the other Execs organised an "inclusive event with segregation" and everyone had a good time despite the publicity buzz from newspapers, mags and videographers attracting many onlookers.
Since this is Bobby's 'baby', he's preferred an "exclusive event without elitism" - and that's the way he's intended it to be.
It IS a fine line to tread - exclusive - but not elitist - but I think he'll handle that quite well enough.
I believe from the outset, he gained formal permission to use the Costco carpark for his own private party (for BNR34s). This in essence means that a private carpark has been secured.
Other than that, I'm not privy to other arrangements.
On with the "Meet n Greet" if BNR34 guys wish to get to know one another better :)
  • Like 1
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
