Thanks mate the test is a IM240 meaning a 240second test he said worst case I'll have to change the cams and injector then should be sweet and a very mild tune he is most worried about raw fuel in the exhaust one drop and I'll fail straight away
Any ideas where I can get a 4 inch euro3?
There are euro 4 cats about now, not as cheap, but you have a much better chance of passing with one of them fitted. You can get them through Super cat, the Magnaflow importer in Melbourne. They also sell the euro 3 metal cats.
As iv said earlier a bf xr6t will have your rb running euro3 standard.
The substrate is about 120mm diameter and 300 long. They work very well. Cost me 100 bucks.
On a side note iv got a xforce 3.5" s/s cat coming. Apparently they are the go
It's only to pass epa so I'm thinking euro3 with 3inch inlets I'll just reduce the 4 inch exhaust before the cat and I'll change it to a venom or whatever after iv done the test I'll just have vbands before the reduces I know it's a stuff around but need to past the test
I would run a stock exhaust for test, with 2 or 3 stock cats, just to make sure it passes first time.
That's what I said to the engineer and he said that it doesn't make a difference he said just get 1 euro4 and I'll be fine aslong as there's no raw fuel
Iv got a 4 inch to 3.5 inch back to 4 at the moment with 2 mufflers and it was 85 dbs the limit is 90 dbs so I can't see the extra .5 inch for half a metre making it 5 dbs louder
What mufflers are you running? That's pretty good for such a large system...
I have had issues finding good 4 inch mufflers, there aren't many online. I usually use Magnaflow but they aren't what I would call quiet.
I didn't know Hurricane made mufflers that large, I will have to get in contact with them. I would assume they only do mild steel though?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
