I got lucky today and found a 125a alternator that looks like a Hitachi and a noticeably wider in the outer metal section between the ally casings . I found it by mistake in a wrecker 92 Maxima with an early VG30 in it . Usually the 110a ones turn up on 97 98 A32 Maximas with VQ30s in them .
The mounting ears are the same with the front tensioner one on centre so to speak . RB alternators being on the drivers side have the top ear slightly towards the engine so need to mod the top bracket to suit the Maxima alts . Maxima VQs don't tension the drive belt by moving the alternatorand and depending on the year and VG/VQ engine can be above or below the AC compressor . I scored a slotted tensioner bracket from an early bottom mount car and another from some top mount Nissan , transverse KA I think . I also got the threaded adjuster block and bolts off some Nissan that tensions by hinging the alternator RB style .
These later alternators have a different connection to the early large spade type . I only have one good plug and I'll have to see what my car has standard .
$45 for a second hand 125a alt sounds good to me , cheers A .
Edited by discopotato03
Yeah I have a string of alternators off various Jap things now starting with an LR165 off a Vortex and the Z32 LR180 that replaced it .
I scored a genuine Hitachi LR1110 (110a) which had been freshened up for the R33 , then stumbled on the 125a one which I pretty sure is a rebuilt Hitachi LR11125 in Maxima casings .
You see the odd copy of Hitachi alts and you can tell by there being no Hitachi stickers and the plating on the nuts and bolts is silver not that gold appearance .
Anyway we split the cases off the 125 and washed it all up yesterday arvo . All looks pretty good though the back bearing is a bit tired .
I honestly think 110a is plenty to have in a car that has 80 standard particularly a 90s Skyline without all the luxo elec pork .
One of my failings is I can't resist rare upspec bits particularly when the bite is virtually trivial .
Must stop collect alternators , cheers A .
Yeah well it works out to around $155 cleaned tested and with new NTC (OE) bearings if the reg rectifier and brushes are good . That's with the help of a mate and the workshop with $50 their way because I don't use people .
The RH9 one has the better front case tensioner mount position but even having to make or mod the bracket it's heaps cheaper and any Maximer alt with the right pulley and socket goes bolt plug . $155 vs 6-900 , the plain lookin one wins .
I'm reluctant to think there is anything special in the RH9 one and if there is it could be higher speed bearings - and lairy paint .
Of course a bright blue pully and stator is worth at least a second in the quarter ... 100% !
A .
  • 5 weeks later...
Any one heard that the I30 160amp are straight bolt-on affair ? a chap in UK said it was straight bolt on on his r32.
I'm trying to buy one from mechman or DC power in the state.. but none are willing to take a R32 case and rebuilt it or make a custom one.. obviously they must think the market is not there and they wont sell enough for them to make it worth it.
  • 2 months later...
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
