Championship Rounds, Results and Classes
CHAMPIONSHIP Results - TBA
2014 SAU Motorsport Club Championship Dates
1st Feb
PI
8th March
Calder
12th April
Sandown
17th May
Winton
16th August
Sandown
20th September
Calder
October
TBC
November
TBC
2014 SAU Vic DECA Dates (Events run by Skylines Australia Vic)
TBA
2014 SAU Track Championship Classes are as follows:
Class A - Modified AWD
Class B - Standard AWD
Class C - Modified RWD
Class D - Standard RWD
Class E - Open
Standard Class:
(List of Free Mods allowed in standard class)
Suspension - All
Brakes - All
Electronics (ECU, Boost Controllers) - All
Intercoolers - All
Pods
Wheels Sizes
Modified Classes:
(Any of these Mods will put you into modified class)
- R Spec Tyres / Slicks under a UTQG rating of 120 tread wear (not including 120)
- A stripped interior. Removal of rear seats only is allowed.
- Any other major weight reduction such as fibreglass doors or lexan windows
- Fuel Systems - Any two out of the following three modifications to either: 1.Injectors, 2.Fuel Pump, 3.Non OEM Turbo's, will put you into modified class. (I.E - Only one fuel system mod is allowed)
- non OEM Fuel Pressure Reg
- Non OEM Engine Capacities (GTST with RB26, RB30; GTR with 2.8L, etc)
- Driving a "supercar" (eg. Lamborghini, Ferrari, R35GTR, Porsche 911 Turbo, GT3, GT2, Veyron etc)
- Non OEM Aero
- Slicks are not Permitted in STD or MOD
Slicks include but are not limited to:
Hankook Ventus Z214
Kuhmo Ecsta V710
Hooiser R6
Open Class
Pretty much defines itself.
Slicks, Carbon body, open wheeler, kit car this is where you fit.
Standard Turbo Clarification
(RWD Standard Class)
RWD Standard can run any Nissan OEM turbo from any RB Skyline.
Highflowing of any of these RB OEM Nissan turbo's is allowed.
(GTR Standard Class)
Any of these turbo's are considered a standard spec replacement turbo and are not considered a turbo mod.
R32, R33, R34 N1's, HKS GT-SS's, Garrett GT2860r-7.
Information for Beginners
Personal Requirements
- Safety helmet (AS1698 standard) in good condition (ie. free of dents and scratches).
- Gloves are optional.
- Leather or suede footwear must completely cover the foot and be firmly fitted. No sandals or thongs allowed.
- Driver apparel must cover the body from ankle to neck including up to the wrists. Long sleeved and flame-resistant clothing is mandatory. Wool is best but cotton overalls or trousers and shirts are also suitable. Race-type overalls are not necessary.
Driver Training - Is not absolutely required, but SAU recommends you make your first track day a driver training day. There is a lot to take in and you wont post a quick time on your first outing. Driver training sessions won't be timed and you will only be on the track with other driver training vehicles. You will have the chance to have an instructor with you, this will typically be another club member who has some track experience. Driver training costs slightly less than the normal sprint days (You wont get to compete in the super sprints at the end of the day)
If you choose to 'not' do driver training as your first event, just place yourself in a slow group and spent the first half of the day following slower cars and learning the racing lines before trying to go off on your own and improve times.
Phillip Island Sprints:
You can do driver training at Phillip Island as your first event, and if your instructor believes you are skilled enough he can allow you to participate in sprints after speaking to the clerk of course and making that recomendation.
If Phillip Island is your first 'sprint' event you will need to provide details of an advanced driver training certificate.
Vehicle Requirements
- Fire Extinguisher (AS1841, AS1846 or AS1848, Minimum of 900grams) Securely fastened with a metal bracket and reachable by the driver from the drivers seat.
- Valve Caps (Preferably metal)
- Boot / Cockpit - Must be free from all loose articles
- Headlights - Any forward facing glass must be covered by tape or contact (This only effects R31 and R32's in the Skyline Range)
- Roll Cages - Must be CAMS approved
- Bonnet Catches - All rear-hinged bonnets must have an additional independent non-flexible strap fitted. Permanent straps/pins attached to the bonnet are not necessary. It is acceptable to tie the bonnet down with light rope. Bonnet Pins are also accepted.
R-Spec Tyres Explained
Competition Street Legal Radial's (Dot Approved Semi - Competition)
In other words they are sticky / soft compound
List of known R Spec Tyres - UTQG
Bridgestone Potenza RE11S - 40
Bridgestone Potenza RE55 - 40
Bridgestone Potenza RE520S -
Yokohamma Advan A050 - 40AA
Yokohamma Advan A048 - 60AA
Yokohamma Advan A032R - 60AA
Dunlop D98J
Dunlop D01J
Dunlop D02J
Dunlop D03Z
Dunlop D93J
Toyo Proxes RA1 - 40AA
Toyo Proxes R888 - 50AA
BFG G Force T/A R1 - 0AA
Michelin Pilot Cup - 80AA
Hoosier A3S03/R3S04 - 40AC
Avon Tech R-A
Pirelli P Zero C
Pirelli P Zero Corsa
Hankook Z209
Hankook Z211
Hankook Z221S
List of soft compound street tyres - UTQG
Federal 595RSR - 140AAA
Kuhmo KU36 - 180AAA
Yokohama Advan Neova AD08 - 180AAA
Hankook RS3
Achillies 123S
UTQG = Treadwear, Traction, Temperature
Treadwear - The treadwear grade is a comparative rating based on the wear rate of the tire when tested under controlled conditions on a specified government test track. A tire graded 200 would wear twice as long on the government test course under specified test conditions as one graded 100.
Traction - Traction grades, from highest to lowest, are AA, A, B and C. They represent the tire's ability to stop on wet pavement as measured under controlled conditions on specified government test surfaces of asphalt and concrete.
Traction Grades Asphalt (g force) Concrete (g force)
AA - Above 0.54 - Above 0.41
A - Above 0.47 - Above 0.35
B - Above 0.38 - Above 0.26
C - Less Than 0.38 - Less Than 0.26
Temperature - The temperature grades, from highest to lowest, are A, B and C. These represent the tire's resistance to the generation of heat
Temperature Grades Speeds (in mph)
A - Over 115
B - Between 100 to 115
C - Between 85 to 100
Track Etiquette
Passing
It is the obligation of the passer (faster car) to make the pass. Do not erratically brake or move off the racing line without first signalling to the faster vehicle behind you.
Signaling
If you want a faster vehicle to pass you, signal with a clear hand pointing to the side on which you wish to be passed. If you want them to pass on the left, then signal over the roof of your vehicle. Do not use indicators to signal passing.
Flag Signals
Flags will be used at designated points around the circuits.
Yellow Flag: The yellow flag signals a situation of danger ahead. Drivers must slow down and show extreme caution. Drivers may not overtake other vehicles until they have passed the green flag.
Green Flag: All clear signal. It is used at the end of the danger area controlled by yellow flags. Drivers may continue on at race speed.
It can also be used to signal the start of a warm-up lap or practice session.
Blue Flag: Overtaking signal. The blue flag informs the driver that he is about to overtaken by one or more faster cars. When the flag is waved, it draws the driver’s attention either to the closeness of the car about to overtake him, or to the high speed at which it is approaching. The blue flag can be shown motionless when the faster car is still some distance away but approaching quickly.
Red Flag: Stopping the race. The red flag will be shown at all posts on the circuit when the Clerk of the Course has decided to stop the race or practice session due to a hazard effecting the course. All drivers must stop racing immediately and proceed to the pit area. Drivers must exercise extreme caution and being prepared to stop if necessary and be aware of the possability of support vehicles on the track.
Black Flag: Return to the pit area. The black flag is usually shown at the Start / Finish line by the Clerk of Course or his marshal. The flag will be shown whilst your vehicle is being pointed at. This informs the driver they must return to the pit area immediately and report to the Clerk of Course.
Checkered Flag: Denotes end of session. Use the remaining lap to cool the car and return to the pit area.
Championship Scoring & Points System
Full points for THREE(3) or more people in class
1st Fastest time in Class - 10 Points
2nd Fastest time in Class - 6 Points
3rd Fastest time in Class - 4 Points
4th Fastest time in Class - 3 Points
5th Fastest time in Class - 2 Points
6th Fastest time in Class - 1 Point
7th and below = 0 Points
Partial points for less than THREE(3) people in class (as per note below) **
1st = 6 points
2nd = 4 Points
** There needs to be at least 3 people representing a class in each round for maximum points to be scored, otherwise 1st can only receive a maximum score equal to 2nd place which is 6 Points.
Notes:
1. Two championship rounds are able to be dropped from the score before a total is achieved, this will be the worst scoring round from the entrant, or an event not attended.
DECA Rounds
Each Sub-Event of the Event will be scored individually.
Points will be awarded in order of finishing from highest to lowest as follows:
1st = 50 points,
2nd = 49 points,
3rd = 48 points,
4th = 47 points etc, and so on down to the last competitor.
All points from each sub event are accumulated and a total is created with the highest score winning. Classes are AWD and RWD.
Penalties:
Hit Cone (Make a cone move from it's spot) = +5 Seconds Per Cone
Missed Gate/Cone (Wrong Direction) = Slowest Time + 10 Seconds.
Did Not Finish = Slowest Time +10 Seconds
Did Not Complete Full Course = Slowest Time +10 Seconds (Missed more than 3 Cones)
Did Not Start = No Score - Nil points
2014 Motorsport Sponsors
Racepace Motorsport
Servicing, Engines & Mechanical
9/6 Holloway Drive
Bayswater, VIC.
PH: 9762 9421
Speed Nation
Automotive Lifestyle
http://speednation.com.au/
Discount City Tyres
Tyres, Wheels & Servicing
626 South Road
Moorabbin
PH: 03 9555 6325
Hi Its my first time with SAU .. be gentle...or rough.. either way im excited
few q's
1st of Feb is the WRX day at PI ?
Do we enter via WRX Club website?
Are all the events $225?
oh and what sort of sponserships are you looking for? I might be able to help with anything tyre/wheel related. pm me with details if its still applicable
few q's
Price often fluctuates depending on track, club & noise limit for the day. $195 usually cheapest day, phillip island often getting a bit pricier.
Entering a day is done through the host car club. in this case, through WRX's website. you'll need your SAU member number and CAMS licence number to complete the application
  • Like 1
Thanks! simple questions but just making it clear for myself.. See you all there, i will be in the busted arse looking bluebird
I plan to be a contender for 2WD modified :D but won't be there 1st of Feb. will scratch the PI itch mid year. Aiming for Calder in March.
got a fair bit of major stuff to sort out with the car, as usual. once turbo, manifold, BOV, intercooler piping and tune done, then it's find source of grease forming on passenger front coil over, fit new pads and rotors...then finally rev limiter, shift light and on and on....
still cheaper than GTR :P
Will be coming to PI for a look, and doing training at DT (although at the moment I'm not sure what/where DT is). Will have to do a bit of work (nothing big) to the car before its ready and thought if I bring it down to the Island someone could have a look at her for me.
On the Topic of PI if there is anything that needs to be done, like setting up tables, putting up flags or whatever needs to be done I'm more than happy to lend a hand on the day.
Ah, I was think DT may have been DECA for some reason. Right now that I know I will be doing the DT in March at Calder if that can be done. Any help or advice would be appreciated too :)
Oh and you can put me down for September to help out as well.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
