Hi all.
Tried to search for the issue, but I didn't have much luck finding anything relating directly to my issue.
Car has a stock blow off valve, plumbed back. Decided to make a plate to block it off, you know for flutter/dose/compressor surge whatever you want to call it.
Car runs great, starts fine, idles fine, holds boost, flutters...
But if I am idling and rev it slightly, then take my foot off the throttle, it hunts for a while then goes back to idling fine. Sometimes it drops to 100-200 rpm, sometimes just to 600, stalled a couple times. It doesn't ALWAYS do it. It is mainly a concern when I am in traffic and need to move forward slightly. Black smoke also comes out the exhaust when hunting. Rich?
Is it because it was tuned with the plumb back blow off and it is expecting that air for idle and isn't receiving it? I have blocked the vacuum line going to the bov and the plumb back pipe. I haven't tried plumbing the bov back in and taking out the blanking plate. Will do that soon and report back.
R34 gt-t rb25det neo
Garret low mount on 18psi
avc-r boost controller
power fc
supporting mods
https://www.sau.com.au/forums/topic/438450-bov-making-car-hunt/
It's because of the reverberation caused affecting the afm.
The ecu sees it as more airflow and adds fuel.
Flutters are not cool enough to put up with your car running shit.
Edited by superben
Or plumb it back and live a happy life. :)
this...seems pretty simple to me mate...you changed something and it made it worse...
Now 'Im not the sharpest tool in the shed but i'd thunk the smart thing to do would be change it back ;)
Mine fluttered with an AFM, had the bov plumbed straight into the intake pipe at 90 degrees, not facing the turbo as recommended. Never had any issues
Mine didnt flutter like crazy because I softened the bov but when it did it was fine
If it flutters, the BOV is supposed to be blocked, doesn't matter if it is plumbed or not..
Yeahhhhh.... It will flutter blocked or with the BOV spring tightish. It isnt 'supposed' to be bocked
How do you tighten the BOV spring?
I didn't think the flutter would have have as much as effect as it did on my car, it is a low mount garret with a LARGE FMIC, and no forward facing plenum. So much frikken pipe work, wouldn't have thought it would have made it that far back..
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
