In their thread they said they were making them in NZ.
China is more likely to make robotic stuff that can pump out thousands, hence all the stainless jobs.
I'd probably buy a china steampipe manifold if they made them lol full-race are robotically welded, and I'm sure china could replicate the tech lol
My mate had an exhaust wheel destroyed on his brand new 6262 from 2 pieces of weld about 1" long which came from inside the manifold where the collector had been welded internally. It was cleaned out thoroughly numerous times before it went on the car but these were obviously right down inside a runner. Better off spending the extra coin on a decent manifold. It ended up costing my mate more in the long run
i am nearly 100% certain these are imported from china and sold from there
probably through Alibaba or Aliexpress, because they look identical :)
Looks familiar?
http://www.aliexpress.com/item/Top-mount-turbo-exhaust-manifold-for-Nissan-Skyline-RB20DET-RB25DET-3mm-mild-steel/1052835806.html
Wow looks like the same turbo kit Hybrid Performance sell too?
http://www.aliexpress.com/item/WSRacing-turbo-kit-for-Nissan-Skyline-RB20DET-RB25DET-Upgrade-430hp/1052572162.html
  • Like 1
you need your eyes checked then!
i would only like to hear from people with ACTUAL experience with Hybrid Performance low mount manifolds (RB20-RB25 IW)
not knob jockeys with hearsay!!
LOL WHOA who are you calling a knob jockey?
These are people giving valuable advice in the form of their opinion, and they are trying to help you make an educated decision.
If its not the opinion you're after just go buy the manifold and axe your turbine wheel in oblivious happiness. Don't come pretending to care about the truth.
My friend bought one, we saw the insides and he then sold it back on eBay and now runs the stock manifold
then thought, hey let's go on alibaba and find one, turns out it's identical (just different photos, in different lighting).
Up to you buddy.
Up to you buddy.
Johnno the knob jockey...stop trying to help.
Has anyone been able to get in contact with hybrid lately??
I've sent him two pms this week so far and he hasn't replied to either...
I was going to buy one untill reading this... Does anyone know where to get brae manifolds & how much they are?
hit up Stao from Hypergear he should be able to point you in the right direction.. they're roughly the same price as 6Boost give or take.
Ahk if their around that price range I won't bother, I think Rex kellway are around $500 from memory
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
