Hey guys got a problem my car didn't make the power I think it should have made.
Rb25det s1
Gt3076r .63 rear
High mount manifold
50mm wast gate with 14psi spring
800cc injectors
Bosh 044 fuel pump
Turbo smart fpr
Upgraded coil packs
Greddy copy intake.
3inch straight exhaust
Blitz dual solenoid boost controller
Microtech Lt12
I only made 296rwhp was the best run of the day at 18 psi
Seems low compared to others iv seen on this site?
Also I did notice that boost drops off from 18 nearly back to 14 at the top. Fuel and air sitting on about 11.6 . Any thoughts?
Edited by DriftSquad
You will need a stiffer spring in the gate imo, and the .63 rear won't be helping things.
Can you get us some pics of your setup? Was the exhaust dropped on the dyno?
I didn't get the chart as I was not happy with the tune. Tuning was done at Godzilla motor sport. On his dynonamics awd dyno
and tell them to send you the tune file
I have a feeling the tune was shit house, also because it's a microtech lt12.. they're so clunky to tune with.. 2x tables to do essentially a single table can do.
I'll ask him to email it to me. Marks pretty good tuner. I mean it is a microguess lt12...
We had to pull some timing cuz she was pinging on boost. He said he thinks the .63 housing is to small
Not sure it's just a stainless manifold with gate mounted to it. The power I Made is not much better then a standard rb with a tune..
If you had bought a decent standalone and left the FFP, stainless manifold, fpr, boost controller etc off the list, you will have had more money to spend on finding the issue on the dyno.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
