I need to buy a trolley jack so I can lift my 31 to do the oil and filter, but I don't know the first thing about them.
Do I need to buy one that would lift more than the kerb weight of my car? I would think yes but that means I need a 2000 Kg one.
What about stands, do I divide the total weight by the number of stands, or does each stand need to be able to hold more than the kerb weight of my car?
Also are SCA (Super Cheap Auto) branded jacks and stands all right for the job, or will they be significantly more likely to drop on my noggin?
Thanks in advance for not laughing too hard.
  • Replies 50
Posted Images
All jacks in Australia have to meet the standard.
You won't lift the entire car up with a Jack so it doesn't need to be rated to the weight of the car, but a bigger/higher rating will lift the car easier and usually higher.
You MUST use axle stands. Don't ever get under a car supported only by a jack.
But can't you just lay on the ground and undo the sump plug with the car on the ground? I can.
Then your car isn't low enough Ben :P
But seriously if you have the cash do yourself a favor and buy a decent trolley jack straight up...Supercheap ones will do the job but I dont like them...clunky and shit in general..Repco pro lift ones are better ,I got a lowline 2000kg one there for 99$ on sale and its been great, left out in the weather for 2 years and still going strong..or if you can get a Costco aluminum one for 180$ they are great, much lighter than the repco jack I have and will get under the lowest cars...Axle stands are cheap as cheaps on sale at supercheap they go for like 20$...get ones with an aframe style they are more stable....but really just as long as you put anything under your car to stop it fallin on your head, blocks of wood, spare wheels anything ..a decent jack will hold but it's better to be safe than squashed...
Aluminium Jack: Rated 1500Kg by Arcan (CostCo) > copies most of what the Blue Point jack has with double cylinder system > $190 approx
Omega Ratchet Jack Stands: Rated 3,000Kg - others may be more/less > But this type is safer than being supported by a metal pin > $50 approx
Low Ramps: Made of heavy duty resin from Garage 88 > supports a car for oil changes, panel replacement etc > $80 approx
All the best...
Nice gear there, Terry. I picked up an alloy 1600kg jack from Hare and Forbes over Xmas - think it was under $200 but not sure.
Those ratchet stands are easy to use, but make sure you inspect the ratchet mechanism an ensure the tab engages well with the teeth in every position. These (cheaper ones) have been known to collapse when not properly engaged.
I think these pin / screw ones being advertised these days are a good idea. They let you adjust the height perfectly, so that you can ensure the weight is more evenly spread across both (all four??) stands.
Only use proper axle stands to support the car. Don't use bricks / wheels / blocks of wood etc (unless the blocks of wood are purpose built, and stable). Lower the vehicle onto the stands - don't rely on the jack. If the jack gives way and drops even 1/2", it can be enough to topple a poorly set up temporary stand. Of course you can leave the jack there as additional support (although take the weight off the jack so the stands are doing their thing.
Jacks very rarely fail, but like anything, when they do, they won't give you a lot of warning. Do you think you can crawl out from under a car before it crushes your skull? Don't take the chance. Use the proper gear.
Wow thanks for all the help guys. I may have to put off the oil change for a week anyway, as I think it's supposed to rain on my day off next week. Will go to costco and check out stuff. #@Terry_GT-R34 thanks so much for the visuals, guess I have to visit Repco as well as try to get my housemate to get me into costco on his memberhsip.
I use the same jack as Terry.
When buying stands, get the heaviest rating you can, some are pretty flimsy.
I usually shove the rims under the car once removed, i even leave the jack under the cross member if room to work, just as a added safety margin.
A few years back a bloke in the next street was working on his car which was held up on a workshop trolley jack and it fell on him, family thought they heard something and found him crushed but still alive, police, parramedics, helicopter arrived, he died on the way to hospital.....so dont take chances....
I wonder if makers of flimsy ones should be crushed Pete? ;)
Yes, wise to put a wheel under each side where possible.
Slide it inside face of rim towards the ground, outside face you see up so you dont scratch the good side when pushing them under on concrete.
You can spew about scratching the good face of the rims after the car falls down and the rims save your life.
Wide rims are nice to have for extra clearance if you have a bit of a pot belly like me. :)
Anything that can support a car, and often a thick chunk of ironbatk or redgum is going to be alot more stable than a made In china pos jackstand....do not be fooled into believing you are safe just because you bought jackstands,get the right jackstands..
As for wheels...do not support the whole weight of the car on them.no...but if you have a car on a jack and no stands available...At least throw the wheels or something under the car to prevent it falling on your head..
If a car falls on your chest you will die a slow painful death...all the air will be squeezed from your Lungs and you will be struggling to breathe so you can yell for help, but it will be impossible...you will slowly suffocate and it will be a miracle if you survive...so put whatever you can under that car to stop it...A thick block of wood will save you, A wheel will save you, a few telephone books could save you...bricks will crack and probably not save you..never use bricks !
Use common sense, Remember a car weighs between 1-2 tonnes and dont give it room to gain momentum...buy a good jack..that crappy emergency jack that's in your boot is just that, an emergency jack they dont last very long when used regularly....
I did not say not to use certain types of stands. Read what I said.
The ratchet types have been known to fail, which is why I said to inspect them and ensure they're properly engaged before lowering the weight of the car onto them. I mostly use ratchet stands because they're easier to work with, so I'd hardly be saying not to use them, would I? Always inspect your equipment before using it - that's one of the first basic safety rules in any workshop.
Blocks of wood. Again, read what I said. I've seen people stack varying sizes / shapes of wood to get the right height. This is about as stable as house of cards and very dangerous. If you have properly sized / shaped blocks of wood (and the correct grade) then this is fine as I said.
In 30 years of working on cars, I've never personally had a hydraulic jack fail, so by your reckoning, it's OK to work under a hydraulic jack, right?
As you're suggesting, just because you have stands doesn't guarantee they will be safe. If used correctly, positioned correctly (and the stands are suitable for the task) then they will be safe, and you won't have a problem. If you want to start improvising with other objects around the house, then make sure they have the right load bearing capacity, and are stable enough to use.
Yes, common sense goes a long way.
I agree, using those ratchet stands worried me enough to go and buy proper 3T alloy pin stands. Plus many of them have been recalled.
I use the Cosco jack and these stands, with them I have jacked up more cars than anyone on here probably.
http://www.ebay.com.au/itm/TORIN-BIG-RED-JACKS-3-TON-ALLOY-JACK-STANDS-CAR-WORKSHOP-DRAGS-RACING-/300859183184?pt=AU_Car_Parts_Accessories&hash=item460c9ad050&_uhb=1
Or for less than a set of rims you can buy a full two post hoist like mine, they are much safer and you would be surprised how many mates would arrive with it.
Where'd you see that one, niZmO? I was looking at some portable 4 posters (I presume all the portable ones would have to be 4 post) and they were around $5k. Sorely tempted to get one for the workshop (trying to juggle 3 cars and a trailer in the workshop is starting to get a bit lame, specially when I need access to all of them.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
