Hey people,
I currently have an rb20det with;
-Z32 AFM
-GTR 444cc injectors
-Walbro 250lph pump
-VG30 turbo (rb20 wastegate) running 15psi off a boost t
-Intercooler
-Cat back
-Nistune
Currently running around 190rwkw.
Now I have in my head two paths to go down.
1st, I was thinking leaving the vg30 turbs on there (has nil shaft play and blades look fantastic still) and upgrading to an E85 450lph Walbro pump, larger injectors and getting it tuned on E85. With that in mind what size injectors would I be looking at 750's or 1000cc's. 1000's seem massive to me on an rb20 with small to mild mods?
2nd path I was thinking was to go a hypergear hiflow and retune.
With either option i'm going to upgrade dump pipe and electronic boost controller.
Just after some opinions on which option would be a better bang for my back upgrade for the lack of a better term.
Cheers Steve.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/
Keep the stock manifold.
As the ceramic turbos are untested on E85 I wouldn't risk it. The theory is sound.. It should be cooler, but theres no guarantee the added power won't push the heat back up anyway.
I also agree a highflow to an appropriate size will yield better and more reliable results.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7197866
no real point of running e85 unless you want to boost the shit out of it. You won't get as much out of it at 15psi. the VG30 turbo won't hold up to that for long so I'd suggest a HG highflow and a retune on 98 for now, save the injectors for later then switch to e85
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7197935
With respect to whether e85 will make life easier on a ceramic turbo....it might, but I wouldn't count on it. The real killer is not heat, it's shaft speed. The mechanical forces acting on the bond between the ceramic and the shaft and internally in the blades rises at some high power of the rpm. Spin it too fast, and it go poof. Fast is either more air or more boost (just look at a compressor map and see why) and for more power (on e85 even) you need more air. With a fixed restriction downstream (the engine) the only way to get more air is more boost. So you're stuffed anyway.
Decision made above is a good one.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7198216
E85 doesnt necessarily mean more boost.
The main benefit is actually the resistance to detonation
I think you should go the e85 path, big pump injectors and tune. Your tuner will be able to add a forkload more timing across the board and make your car drive more fun.
If you go the larger turbo route you'll definately get more lag, less time near boost in a street car and not enjoy it as much.
Or since you didnt mention dump pipe go kando td05 and wind up the boost :-)
My 2c worth
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7198416
Exactly right, you can either add timing, boost or both. I chose boost and it works very well also.
I figured pushing the turbo hard was better than relying on the rods to take extra load, seeing they are stock.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7199989
I thought about it for a bit and came up with if I push the vg on e85 and it lets go I'm up for a turbo anyway.
So I'll get the ss1 in tuned and running and then look at e85 once I'm happy with how the cars going at that point in time.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7200639
I'd just get bigger injectors / pump and get it all tuned at once with the ss1. The money you'll spend on the re-tune you could have almost done the fuel system.
I just sold brand new unopened id1000's for $500 and bought a walbro 400lph new for $190.
A tune will usually set you back $500-$600
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7201463
For the sake of starting a new thread,
Just sussing out some more options, one of my current injectors is leaking (replaced o-rings and no difference, i assume its cracked maybe?). Im going to upgrade pump and injectors now as well as the SS1.
Basically question is should I just keep the resistor pack and stay with low imp GTR injectors, or revert back to the standard RB20 setup and look for some high imp injectors?
I've noticed there's a sale on RHD at the moment on SARD 800cc's too.
Edit: Also going to pick up a new Walbro pump, if I get the E85 compatible pump will it be safe to use 98 for a while and then when im ready switch to E85 later on? Or is it designed solely for E85?
Edited by Tonks
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7208728
Go with deastchwerks, they're bosch ev14s, high impedance and drop in fit for the RB20
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb20det/1989-94-rb20det
Edited by Missileman
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7208776
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
