Ok gys I've decided to start off with i will just go for
-Fender brace
-Floor brace (behind front seats)
-Tension rod bar (easy to find)
Not sure where I will get them from or what brand but hopefully I end up finding something.
Ultimately though The bracing I want to get most done was something to prevent Flex along the horizontal axis dead smack in the middle of the car, so thats why a multi point underbody brace would have been perfect, but I have yet to find one for a GTS.
Do you guys know what these braces are called and where to get them
Edited by sonicz
This whole topic just screams waste of money, sorry but i was young once and i spent money on useless items too but i didnt have these forums to learn from others though.
Dont waste your time or money on this car, drive it be satisfied and save to get something better in the future.
In truth all braces will do something. I remember when I first put my suspension tower brace on and there was in fact a noticeable difference provided you adjust it so it is actually putting tension on the towers. Then of course the usual Bilstein, coils thing. Big difference. Then after a few track days took the car off the road and decided stuff it, I'll start at the heart of the problem. The subframe. Every bush changed. Some difference there. Every suspension arm, bush, tie rods, ball joints, there is nothing left on that car that's sloppy. I love it, precise, sharp steering. Out of all that was changed I would have to say the biggest difference was the suspension arm bushes. Polyurethane everywhere. Steering rack as well. My experience anyway. Out on the track the car is worlds apart from the standard suspension. A side note: don't mistake flex at speed with the tyres fully loaded under cornering as chassis flex if you have street tyres on it, it's just side wall flex.
Those chassis braces you are looking at are seriously flawed but I suppose if all of them combined make a difference then go for it. Always remember the least flexing shape is a box. Putting chassis braces under the floor won't do much except give your suspension points less flex but your actual body will still be flexing. The proper way to do it would be to weld a 4 point cage in between front and back seats but only if welding the top of the cage to the top of the B-pillars. Now you have a far superior chassis to play with.
  • Like 1
What exactly are you comparing your car to? Mine feels plenty tight enough with softish coilovers, subframe collars, a couple of bushes changed to polyurethene ones and a front strut brace.
I think once I do sway bars ill be pretty damn happy with it, will be very nice for a street car
Does the car have any previous accident damage? Im not sure how tight you want it to be so not sure if its just something not quite right with the car or its just not quite at the standard you want
not sure if do-luck has it for your car but maybe u can get some ideas?
they have this brace along the length of the car... made of aluminium. called the floor support bar.
http://www.do-luck.com/tuningparts/assistbar/floorsupportbar/index.html
then there is the rear cross bar that sits behind the front seats to prevent mid chassis flex... worked wonders for my S13 then. u can even tension it.
http://www.do-luck.com/tuningparts/assistbar/rearcrossbar/index.html
also, nismo has something for the GTR... again, maybe it might give u some ideas? under floor reinforcing bar
http://www.nismo.co.jp/en/products/competition/lb/reinforcing.html
Those Nismo ones that require you to bolt to the chassis rails would not be likely to be legal here in Aus. They require modification of the chassis rails which is generally a no no. Also, most Skyline chassis rails are already dented upwards in that area (already a defect) due to lack of ground clearance / driving over bricks or whatever. Bolting on something to further reduce clearance there isn't a great idea.
Just something else to think about.
^^ I think only the Ultra Racing brace reduces ground clearance, all the nismo brace don't do this, if you have a look at both picture on the nismo site, the lowest point if either the gearbox mount or exhaust
EDIT: The picture posted by Sonicz from the r33-gtr.com website is the stock brace that comes in s15s rear boot, just find someone wrecking s15s and you can easily score them for next to nothing
Edited by ichi-go
No. Look at this one from Nismo
It's under the chassis rails.
Cage it from front to rear. 1.75"x.250" chromoly tubing. Put it on a frame jig to keep the uni-body frame straight. Only way to get what you're looking for. All this bracing from Japanese manufactures is big $$$$. Over priced for what it is to me. Find an actually race shop not just a average joe. Race shops been there and done that. Probably answer your questions better also.
Examples:
post-116132-13933971845538_thumb.jpgpost-116132-13933972005261_thumb.jpgpost-116132-13933972151734_thumb.jpg
Obviously this is a S-Chassis but it's all the same. Car gets tweaked every direction and all is good.
Do it. brace everything. Report back.
Thats not really the approach I can tak as it seems really difficult to come across some of these items let alone everything. I was hoping to find used bits here and there I can just bolt to the car for cheap, and to be honest I had my heart set on a multi point underbody brace the most. Definitely no roll cages and intrusive bars in the cabin.
So far just getting the tension rod bar and STILL looking for a fender brace but cant find one.
Yup that makes a lot of sense. I have seen wreckers selling parts or even throwing away body parts like this so I figured it would be a cheap exercise. I was wrong.
I'm comparing my 33 to almost every other car I have driven, and it just creaks and bends and wobbles on driveways and over bumps. The chassis feels like its made of halumi cheese. It takes seconds for the body to finish reacting to a bump. I Have driven other R33s and they feel very stiff and taught in comparison.
Mine must've had a hard life since the previous owner lived in a rural area so probably many wobbly up down roads, and my driveway is on a funny sideways diagonal angle making the car softer each time I drive in and out.
Subframe collars probably did your car a lot of good. Mine is stock in that regard, but I do have some poly bushes and a strut bar.
Have a look at what this Japanese owner says about the body.
"3. Usual used GT-R's body have come loose. The parts to tighten such a loosen-body are available at HKS-Kansai.
These are the photos of my R33 GT-R, showing the body reinforcement parts, I installed the "refresh-bar" of HKS-Kansai. This parts is very good to reinforce the body. This refresh-bar is designed for not making sacrifices for daily use of the car."
http://www.geocities.jp/r33gtruser/usedgtr.html
Also have a look at what nissan did with the next few cars they built after the 33 and 34. Look at all the chassis bracing on a stock 350z.
http://youtu.be/aG6X72FS6gc?t=20m48s
The 33 is listed there but not really sure how you order from there. I was hoping somebody has these bits used in AUS.
Edited by sonicz
just had another look at the products on the Ultra Racing site, and first thing tomorrow I am having my solicitors draft a letter to them requesting they change their name to Ultra-Anus, reflective of the usefulness of their parts. I would seriously look at the bolt-in cage idea for stiffening the chassis, a cusco cage, that allows use of front and rear seata, will only be about $850 delivered, which is only the price of a few of those braces, just in one lump sum.
It really does sound like you need new bushes mate, if the car takes a while to settle from a corner or a bump? Creaking? This would be due to worn out bushes and shocks.
If you can't afford all of them at once, just get upper and lower control arm bushes first, swaybar bushes are cheap. And then buy some solid strut tower bars front and rear and some sway bars front and rear and new shocks front and rear.
Yeah but if you look further down the pic towards the middle/side, you can see the gearbox crossmember is the same height as the brace hence why it wouldnt reduce clearance
The Ultra-Racing one however is different story as the mount where the bolts go to come downwards and will reduce clearance
st
Sorry I missed this. Its probably the most relevant post in this thread to me.
So you are saying that brace bar that runs accross the very back of the boot comes standard on all S15s and I can find one by looking for S15 wrecks and it will fit a ECR33 chassis?
Edited by sonicz
Yes
http://www.r33gt-r.com/2013/07/trunk-bar-another-noticeable.html
About fitting the ECR33, just look in your boot to see if there's any predrill holes, according to the blog, there is predrilled holes on r33 gtr series3
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
