  • 4 weeks later...
Updates time.
Gave her the fastest bath of her life. And a quick cover with Zaino.
Still need to fix the drivers headrest of the nismo covers. And give the interior a clean......
So... How to tell i like nismo? Also i just noticed i need to straighten the horn... lewl There is also a Nismo boost gauge in the circle vent... Missed that in the pic.
Will get some decent shots when i can....
  • Like 2
I'm still doing short term oil changes, will swap to a genuine filter when it's been driven a bit more.
Next order ill order another nismo sock for the oil filter....
Also looking into options for the battery. Possibly a stand+enclosure welded up.... at the moment it's literally propped up with wood hahahaha
Few questions...
The black fuel line that runs over the plenum.. Should i braid that for the lulz?
Also considering either braiding or getting one of the old school greddy hard pipes for the top Rad hose...???
I finally managed to get my hands on a decent condition optioned up foot rest, and i didn't have to pay drug (nismo) money for it. Pretty stoked. When that arrives that means the interior is pretty much done. Unless as stated above i want a nismo cluster and/or the optioned knee pads.....
Gearbox has a slight crunch 4th syncro.
Or new diffs? !!
  • Like 1
Just now, ActionDan said:
Tip all of that money you might spend into my car instead, know that it went to a good cause?
I'll tell you what, you give me the car and ill spend all the money on it.
An interesting counter offer....
The car did come from Canberra actually, maybe it was always meant to be yours.
As for your list, I would rebuild box. Reliability/avoiding further damage over upgrades IMO.
Edited by ActionDan
22 minutes ago, Robzilla32 said:
Why Quaife instead of Nismo at the front?
A lot of ppl seem to prefer them over the Nismo. I'm not sure why as the reasons they specify it sounds more like a setup issue personally.
Personally I've been in a couple of cars with Nismo front diffs setup correctly by RPM and they were fine after run-in.
I'd do transfer case mod>front diff> rear diff (in that order)
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
