My tuner here in canada managed to tune a rb28 with gt860-5 with stock cam I believe and it made 640whp on a dynapack.
I can say I have all the supportive bolt-on mods you could get + haltech ecu + aquamist kit. running 3 inch exhaust.
Do you think/ have anyone made the test on a dyno I would be gaining something ''worth the hassle'' of an exhaust cutout on my RS*R front pipe ?
If we're talking 10whp, with no extra torque or more responsive engine, I think we can say its not worth to hack a RS*R pipe + the cost of labour and cutout. However, if I can make the engine more responsive, add 15 lbs of torque .. then it could be interesting.
Your though ?
Can you elaborate on what you mean by cut out?
640whp is mega. I believe Piggaz is the only one in Aus running just shy of that with -5s on an RB28.
General rule of thumb is that if you drop your exhaust before the cat and gain lots of power you have a restriction in your exhaust. Otherwise you should realistically be looking at 10-20whp tops.. And a 3" system should support close to the asking price.
3 inch?
Throw that in the bin and put something decent on there.
How much boost and what fuel are you running to achieve those figures?
I'm running a twin 3 inch system on my car.
As a comparison, GT RS's at 2 bar made 414 rwkw using a kakimoto full mega N1 (rubbish catback which was 80mm into a 90mm into some peanut rear muffler which at best would have been 2.75 inch inside). Going back to -5's, from pods to stock airbox and the much bigger exhaust netted 426 rwkw at 23 psi, cam gears and the rear of the setup remained unchanged. Same car, same tuner, same fuel, same dyno. At that power level there is much to be gained.
Dynapack is a hub dyno where Paulie is on a chassis dyno so I think Paul is still ahead, just
3" exhaust IMO is to small for that power range and I'm sure you would pick up a fair bit with a 3.5", but as already mentioned drop the cat and run again and see if there is a restriction in the rest of the exhaust
heres the cutout I'm looking for and will be installed before the cat :
I wanted to drop the catback and see by myself.. but the tuner said he's not a fan of messing up with the car while the car is on the dyno.. so if I have to pay 300$ just to see if theres a gain, I might as well pay 300$ to buy the cutout and have it installed lol.
3 inch?
right now tuned for 23psi with 94 octane (us fuel) I'm running r34 dump ( 58mm) to a RS*R 70x2 to 1x80mm all the way to the end (no cat). Already bought myself a set of 70mm dump pipe, would just need to install a cutout right after the merge to unleash more flow. ( I have no choice to run max. 3 inch exhaust if I dont want more cop attention than my skyline already draw lol)
Edited by cobrAA
That cut out is dodgy as hell and if you put that in your front pipe here it would be an instant $10,000 EPA fine
Not to mention it would drop back pressure from your engine leaning your motor out, do it properly and up grade the exhaust with the dump pipes you already have then a matching front pipe with a 3.5" outlet and the 3.5" cat back
3.5" exhausts can be made very quite with good quality mufflers, I had a custom twin 3" into single 4" made for my car and it is quieter then the 80mm jap spec that can off it
Why can you not run a bigger exhaust? Is it the noise or just the size of the pipe that attracts attention? Going to 3.5in from 3in will allow roughly 35% more flow.
Both! but even if your car is quiet.. a big pipe will still draw useless attention.
Well, i tried and couldn't find any quiet resonator in 3.5 inch. So I decided to go the cutout route, but since you mentionned that 10k fine, I can see now why in Aus, guys dont put cutout. we don't have this fine over here.
it all depends on the turbo and what its capable of...wont get much if you have a 3 inch turbo outlet flange and go 4 inch in exhaust. Gotta increase flow from the source then work your way down.
Sort of.
It will surely sound very angry, but I would only activate it on a drag strip or on a highway if I meet with a modded supra hahaha. I'm just scared that I will gain little with this mods. Like, how many have been able to break the 600whp marks on a dynapack with a pair of -5s ( on a rb26) ? Not to mention when I did 576whp, I still had stock intercooler, no water-meth and nistune maf ecu.
Edited by cobrAA
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
