hi guys tell me some stories about the poorest rb30 twin cam conversions youve done or mates have done. like high kms non rebuilt motors and non rebuilt heads and stuff. what power ya made and for how long?
im doin one i think. got rb25 na head for $50 but will need valve springs and getting rb30 motor for $80. last one was ment to be a slapper but got sidetracked and rebuilt motor and head. hopefully stay poor this time
It wasn't really a slapper because I did go a forged bottom end....but I did reuse the original stagea head without refreshing and it has about 300,000klm on it now. getting a bit smokey on deceleration but still makes the same power it always did (250awkw)
No machining but but cleaned up and new rings, bearings and conrod bolts. Currently on 314AWKW done about 50,000km blows a little smoke but uses very little oil between changes. Worth doing a roughy but if I had the money I would have preferred a rebore with forged high comp pistons and a good balance (rods and crank would be fine as is).
I am putting together my 25/30 at the moment. Will be used for drifting so will see some constant high revving (will set rev limiter to 7000) and I was planning on just tearing the block down and cleaning everything (pistons/ring/rods). Will also be chucking in new ACL bearings all round. Is it worth going ARP main/head studs and rod bolts.
Trying to toss up whether going ARP all round or reuse the standard gear. Any advice for a first timer appreciated :)
Surely people have seen what Simon_s14 is doing with an untouched bottom end.
400 plus rwkw!
I am running an untouched wrecker bottom end for 295rwkw just got a bigger turbo and water injection so will push it harder.
Also did nothing to the head, aside from weld up vct gallery and run external lime (neo head)
I went to put a tomei oil pump on my forged 26/30 to find it hasn't had a collar installed when being built so I'm putting the head on a standard 30 bottom end with t78 and e85 and going to see how far I can push it while I save to get the good bottom end ready to go
400 plus rwkw!
I certainly have seen his results mate, it's essentially what I am doing except fresh bearings and when the bottom end grenades I can reuse the studs again.
Also you will be copping a lengthy PM soon, have quite a few questions saved up about the conversion as I too am doing a 25/30 NEO :)
the whole reason that mine is so reliable is because i left it alone.
dont f**k with it and it will work.. dont change bearings or rings for a freshen up.. just get a good cond running engine that you know works, pull it out of a 31, put a head on it with quality parts and support systems and it will serve you well
  • Like 1
What would be minimum compression result on the comp guage if looking at a running rb30? im guessing over 150psi would be a thumbs up?
Probably have to buy the whole wreck/car unless you are awesome with tools and have a car hoist handy?
Edited by AngryRB
its easy as... drop the sump, then undo the large pressure relief valve nut, inside is a spring and a ball bearing. leave them there, then get 2xm6 flat washers (i used spring washers and then bent them in vice to become flat) and place 2 of them on top of the spring and then refit the cap. reseal the sump.
should get an extra 20psi out of it.
Cos you seem nice heres a pic.
The thing to undo is the gold coloured plug in the bottom left of the photo.
You can see the bolts that hold the sump on near it along the bottom of the pump,so should be clearer for you.
Also shows you can't take the oil pump off without removing the sump.post-107339-0-05878100-1395038977_thumb.jpg
I'm prettysure You can't take the sump off with the engine in the car.
The oil pimp stays on. When you take the sump of you will see the plug Simon is referring to.
Yeah sorry, i mean to say on the engine not in the car, it definitely cannot be done in car as you can't take the sump off at all.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
