Some Euro-trash. Just put some 12.5mm spacers on the front of the BMW and lowered it around 1.5" all around. I think the rear could comes down a little more but overall I'm really happy with the stock-but-tougher look.
  • Like 1
My Supra
Twin hybrid turbos, cams, decat, exhaust & a syvecs. Should be running about 450-460hp. Desperate to get back in a GTR though :(
What's missing from the Supra that you'd be keen to get into a GTR for? Never driven a Supra so keen to know.
My Supra
Nothings missing as such, Its a brilliant car to drive & is a lot of fun on the right road (on others its down right scary :laugh: )
I'd always wanted a GTR & sold mine way earlier than I wanted to :( Got some unfinished business with it :D
Yes!!! Love the 996!!! (Love the BMW also!!) Nice cars!
My Supra
I like that! I'd hate to know how much you spend on fuel in it though with UK prices! :O
Sensual....
  • Like 1
Very nice collection mate :thumbsup: Still have a big soft spot for the E36 M3. Yours is a 3.2 (Evo) yeah? A 1996, judging by the series 1 grille but series 2 rims, clear indicators and Estoril colour. Props if it's the 6 speed manual.
Here's my other contribution. 0-100km/h in 7.0 flat, not bad for 1970kg! :D
  • Like 2
Matt, what is it a 740 or 750? You know your Beemers as you're spot on. It's a 96, 3.2 Evo and yes a factory 6 speed. Most of the SMG cars are now manual converted as the pumps die and they're $9k for a new one, and all for a transmission that doesn't work that well at best. I love the way they look!
Most of my cars are what I ached for as a youngster but could just never own because of the $$. Ahh, nostalgia.
Enjoying this thread,
Super cool. I bet it's nice to drive? But 1970kgs!?! Holy schmoly thats a large lass!
Cheers boys! :) Christian, it cost a fair bit to put right (but would've cost even more had I bought parts from here instead of the States) but it was fairly cheap to acquire. 1 owner car with books, so that gave me some confidence. And yep you definitely feel the 5.1 metres and 2 tonnes when cornering, but it's sooo relaxing to roll to work and back!
Yeah Nick, it's a '99 740iL with the M62 4.4. Like the S52 they can have some Vanos issues but otherwise pretty solid unit as long as it gets the proper maintenance. Ah ok, I have seen quite a few converted ones on Carsales. I know a little about the E36 M3s as I have been very close to buying one in the past, just couldn't find the right one. I can totally relate to the idea of acquiring cars that one used to want as a teenager too. The E38 and the GTR are two of those cars, for me. So I consider myself lucky!
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
