Hey people!
I have little to no knowledge when it comes to lowering a car - my old Magna was in no need of any loving!
But i recently got my new stag(and fell in love...Of course!!) But, I'd like to lower it just a little, im thinking 30-40mm? I don't want to be bottoming out or anything, just like sit a bit nicer.
Here she is:
I'm in Adelaide. Just interested to know how/who/where i can co about getting my car lowered?
Also, Red Brake Callipers, yay or nay? ;)
Thanks heaps for any input!
https://www.sau.com.au/forums/topic/440535-how-can-i-lower-my-stag/
Nice looking stag mate.
To lower it you need to get suspension which is lower. Any reputable mechanic or suspension specialist can do it.
Hit the search feature on the forum to help you decide what to get and how much it will cost.
Do you want it to be legal? cheap? for track or road use? You got some homework to do bud =)
My old 33 had Pedders lowered springs on the standard struts and that was perfect for my use. Still legal and looked better.
Edited by Sklyn
In adleaide, unless I read it wrong the minimum height for a stagea to be legal is only 5mm lower than stock. Also in sa you need an engineer certificate for coilovers, which no one actually gets. But keep in mind you could be defected for them.
You can find second hand sprigs for sale everywhere, I have some but am located in Sydney. You should be able to get something for under $200 if not let me know and I will send mine down but don't know how much freight is???
Thanks mate, yeah I'll have a look around! Sorry if i come across as a clueless retard but essentially that's what I am :rofl2:
Just not sure what you look for in springs? Length, type etc.
cheers!
Hahaha! Well I'll look for springs but in the mean time i'll dig up the back paving and load my boot with it ;)
Out of interest is there a guide anywhere for how to change the springs on a stag?
I did have a skim through but like i said, I wouldn't know which springs i would be after? I don't know the specs of the current ones, I just know i want my car about 30-40mm lower :yes: Cheers!
Dunno what the compatibility is between R33,R34,Stag etc but King Spring Lows are generally 30mm lower than stock.
Same with Lovells or Auroras I believe.
If they will fit, they should do.
You are after something like this:
http://www.trademe.co.nz/motors/car-parts-accessories/nissan/suspension/auction-705157498.htm
I use Google for most things as the answers more often than not come from this website e.g.
https://www.google.co.nz/#q=how+to+fit+lowering+springs+on+a+Stagea
but there is a Stagea specific DIY section at the top of this page and also a general DIY section here:
http://www.skylinesaustralia.com/forums/forum/57-tutorials-diy-faq/
You said you want it legal. I have already posted you can only lower it 5mm in sa.
Search for yourself,transport sa have all of the minimum heights for all cars on a website in pdf format.
So you want legal on sa-you can't lower it.
Wow 99%!of stagea's I'm adelaide are illegal !!
And you can't tow with them at all ??
Government listing is only for auto model too looking at the track?
Could you imagine the hassles at regency lol.
This is why I keep all my cars 100% stock
Australians all let us rejoice for we are young and free !
Cheers for all the input Ben!
For interest sake what are those figures referring to?
Hmm do any of you lowered SA guys get picked on?
Edited by sekay1994
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
