Hey there, just joined the forum and also just got me a 91 r32 GTR, I'm kinda familiar with the car, didn't see or talk of many growing up.
But I'll just get strait to the point, I've got this great car and i want to throw some money in it. So far its stock I've got a basic understanding of modding a car but i figured because there's so many people doing it on here maybe you could point me in the right direction. Any help is appreciated thanks.
https://www.sau.com.au/forums/topic/440558-rb26-basics/
Consider yourself pointed in the direction of the rb26 dyno results thread stickied in this forum.
Or by pointed in the right direction do you mean have exactly what to do to your car spelled out to you based on not specifying a budget or goal?
Sorry if that comes across harsh,but seriously all the info is on this site,and your question can't be answered as theres not enough info.
Edited by superben
https://www.sau.com.au/forums/topic/440558-rb26-basics/#findComment-7228988
No worries dude.
There is obviously heaps of advice to be heard, but without having a goal and budget in mind it's all a waste of time
I would start with a full change of all fluids,plugs, timing belt,tensioner,cam seals, etc to make sure you are starting with a solid base.
One you start modifying it you are opening up a bigger money pit!
https://www.sau.com.au/forums/topic/440558-rb26-basics/#findComment-7228990
Something tells me this is either a troll or someone who bought a car before doing any research AT ALL!!!!
You have a stock R32 GTR that you are wanting to smack 2JZ's with and run a 9.66....... do yourself a favour and sell it as i can see the next thread being 'i got done street racing' or 'my engine blew up, what do i do now?'
https://www.sau.com.au/forums/topic/440558-rb26-basics/#findComment-7229055
lol, i just re read it and read it properly, sorry dude :(
As has already been said, the first thing i always told people to do was a fluid change, water pump and all timing belt bits (belt, bearings, bolt etc.
Good oil is always going to help and i have ALWAYS used Motul 300V 20W60. Have used it in so many cars with minimal wear on even race engines.
A decent catch can will help prevent any blow by going back into the intake which helps in many ways
Last but not least pray to the car gods that the oil pump doesnt fail
https://www.sau.com.au/forums/topic/440558-rb26-basics/#findComment-7229160
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
