Hello about a year ago i had one of my big bearings go . I had them all replaced and a good condition second hand crank shaft installed . All was fine until a couple of weeks ago when my car started to have a miss when i really put my foot down but it would go back to normal about ten seconds after. But then i was just driving normally oneday and it suddenly started to miss permanantely . i changed spark plugs and it was still there i played with coil packs found out the noise of the engine would stay the same with number 6 plug . so changed front coil with back and it still stayed the same so it wasnt coilpack. At this stage i couldnt figure it out so i took it to a mechanic. He beleives that the piston has hit the spark plug and thinks its a big end bearing gone again. The cars oil pressure was fine and had no knock from the motor or flashing dash lights like last time . So im just wondering if anyone has had a similar problem. or has a better idea of what could be going on?
If it is another bearing there must be something wrong with my motor . im only running stock boost . Mechanicsaid i either get a second hand bottom end or just get new bearings. rb30 bottom end could be an idea too?
https://www.sau.com.au/forums/topic/440753-piston-hit-number-6-spark-plug/
Why not try unplugging number 6 injector? That would be the obvious next step for me.
I don't understand how the rod could stretch that much to hit the plug. Even if it did, the problem would not have been intermittent in the first place.
I have seen pistons hit the head, and it was making a fair noise by that stage. To hit the plug you would have to be running a longer plug than recommended. My suggestion, try another mechanic.
could be hundreds of things before that mate.
coil parck harness could be stuffed on no 6.
soark plug could be cross threaded
head gasket broken, rings gone, head cracked.
a missfire can pe a pita to diagnose.
but if the piston had hit the plug youd know about it....
Yes but BCPR6ES or BKR6EYA or XYZ123AB-C???
And funnily enough all the other letters mean something also. But no one cares....
http://www.ngk.de/fileadmin/templates/Dokumente/EN/downloads_not_used_in_download_area/ngk_zuendkerzen_code_en.pdf
Pull the plug, use a bore scope and have a look around inside.
IF you used the correct length plugs there is no way the piston would close the plug gap, the sides of the piston would hit the head first and you would hear that from a mile away.
Im wondering if you dropped a valve guide in there.....bore scope will soon find out....
Something hit your plug to close it and i highly doubt it was a piston.
There is always a possibility that the last person to fit the plug dropped it off the socket as they were fitting the plug down the hole and it closed the gap considerably, these things can happen when people are careless, ive seen this in the past on a number of engines where they didnt have the rubber sleeve to hold the plug into the socket in good condition and the plug just slides off and drops down into the head closing the gap.
Anyone who has this happen should get the plug out and recheck the gap before putting it back in.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
