hi i have a 19912 r32 gtr that ive been having issues with ever since the day i bought it, im from canada and i posted on gtr canada and didn't get any responses, i searched for days on both forums and i couldn't find any help with my problem. so i did a compression test and all cylinders are 135-140psi range and i swopped out spark plugs and coil packs and checked power to my wiring harness and its all good, but theres a miss you can hear through the muffler, the car wont idle up over 4k and the boost wont go over 5psi, i changed ecus and checked mafs and they all good, im stuck and dont know what to do from here any input would be great thanks.
  • Replies 44
I switched coils over to a working coil pack and it still did the same thing, I unplugged one of the working coil packs and there was a drop in revs and rough idle when I did it to that cylinder where I had the problem there was no difference to the idle or drop in rpm it just ran like normal
Um......still not following you properly.
Did you swap out 6 coilpacks to 6 known good ones, or did you only have one known good one to swap in?
Following from that, it sounds like you swapped in a coil on the cylinder where you have a problem. But it is not clear if the problem stayed even with a known good coil. If that cylinder still refuses to fire with a different coil on it, then the problem is not the coil.
If the situation matches what I said above, then it is likely that either the loom is faulty (the plugs and connectors inside can get corroded or broken) or it could be the ignitor module. Those modules are famous for dying and killing only one cylinder. You'll need to swaptronics with a known good one there too.
Ok thanks for your help, do you know of any aftermarket igniters available? And I'm going to put my multimeter on my loom at work tomorrow and see if I can find a problem with the loom.
http://www.moristech.com.au/Moristech%20Price%20List%201st%20August%202010.pdf
The 6 channel ignitor.
  • 3 weeks later...
so my car seemed to run good for a few days, i was not driving the car because of the snow and im getting it inspected, but now the mis fire is gone really bad, i found a boost leak between the intake manifold and intercooler, theres spark at all the other coils except the coilpack closest to the fire wall, i need help please!
Have you changed the ignitor module as previously mentioned ? That is most likely your problem
If not then CAS next, both are well known to fail and drop one cylinder
There is a thread in here with instructions for swapping the GTR ignitor with the Z32 300zx one which is less known for failure
Yes xklaba I've swapped the ignitor with a known workings ignitor still no luck, the car boosts great now and wants to rev up but the mis is just to bad. It's also a little harder to start, won't start without a little gas, I've stripped my wiring loom and there was a bunch of joins in it, ok not sure if they were supposed to be there but doesn't look like a factory harness would be spliced joined and taped.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
