If there is a problem with the muffler or resonator a restriction point can sometimes be indicated by heat marks , brown usually. The only accurate way to find the culprit is to pressure test the system on load. The starting point is engine side of cat. The reading is the summation of all restriction in the exhaust.Repeat this process in front of the remaining components. Where the pressure drops indicates that closest component towards the engine is the culprit. If there is no pressure drop , remains high then it will be the rear muffler.
Have you got a dyno graph, HP v boost
The angle and location of where the WG rejoins the exhaust is less then ideal IMO, it should have been put into the back of the bend at a less angle
If the cat is 100 cell 5" bodied and intact it shouldn't be a problem
They should have dropped it to confirm, I'd agree on the CAS been a possible problem as already stated
If the cat core is intact it should be ok.
The WG merge point could have been a little better, and angled a bit more shallow. But it doesn't look too bad.
Offset mufflers - depending on internal construction - can provide bigger restriction. Some simply use a slight kink with a full length internal perforated tube. They are little different to one that has a straight internal tube. If yours runs bulkheads and chambers then yes it could be an issue.
That mid muffler definitely needs another look, the rear outlet seems to be necked down. Get that measured and be prepared to modify/replace/delete it.
Thanks guys I have doubts on the mid muffler as well as its seemingly necked down at the back, unsure about front, will check. Is it a stock item, and if replacement needed then just get a generic 3' in/out mid muffler right? What about the xforce rear oval muffler, anyone here made 310+rwkw on that? Confirming that cat is intact, was dropped last week
Unless there is something we can't see, like a piece of metal welded poorly inside the exhaust, it won't be your issue. We can debate it as much as you like Ron, but you could have dropped 2 bolts, seriously less than a minute, and you would have known if it was a problem or not on the dyno. There are a few issues that can limit power like that and jumping to conclusions won't fix any of them.
Get it back on the dyno, (make sure you have the cam timing checked first) drop the exhaust during the run, if that fails change the cas on the spot.
Thanx Scotty - its goin back Monday for a quick check with Yavuz, will ask them why they didnt drop the exhaust seeing as the conclusion was made that its definitely the exhaust. Cam timing as set by me with timing gun and confirmed by Mark is spot on 15degs at idle and also on PFC. I took cat off last week to hammer out some welding dags where the flanges welded to the cat. Hope I havent shattered out the innards with the heavy hammer/screwdriver blows to thedags.. ;S.
Where is the thread about Anthonys CAS on the R34GTT, couldnt find the link, if you dont mind posting here? Would like to read cheers
I used a 3inch xforce rear oval muffler for 320 easy kw's, doesn't look as nice as your one though. Can take a pic of the insides to compare if you want.
  • Like 1
Updates on exhaust study: discovered theres a taper at where the rear exhaust pipe joins with back of mid muffler. Exhaust confirmed 77mm outer dia (3 inch), that taper is 69mm (2.71inches) :( XForce rear muffler is fine, seems to have an angled inner pipe to offset at back entry. - inner dia looks small? :( !
I think there's a bit more to these Japanese cat back mid mufflers than meets the eye . They're more difficult to see on the car let alone look through and Jasma systems were made to be quiet . If your bolt on import only got modest upgrades some restriction may not have been a big issue . There are limits to how deep that mid muffler can be and from memory there is a bracket bolted across the tunnel in a 33 anyway that limits the length of that mid muffler . The numbers I wrote down are 5 x 10 x 16 inch and that's a Nismo in cat back one - no idea what it's like inside .
I spoke to Wolverine about this stuff yesterday evening and it's beginning to sound like the best mufflers need to be made because the generic ones are too big or too small .
The rear ones like that Xforce could be slightly longer and deeper for Skylines but they're obviously intended to go into other cars with a little less space - so one fits all .
The best scenario would be a run of the biggest straight through mufflers that will fit 32 33 34 made up and a group buy , 3 and 3 1/2" would keep most inc the GTR people happy if quiet .
A .
I find that magnaflow make a good center muffler that fits nice and neat and is in 3,3.5 and 4" sizes
I modified a HKS super drager rear muffler to make it 4" cause it has a big arse barrel around it meaning there was heaps of room for sound deadining around the 4" pipe
At these power levels custom is the best way to get the flow and keep sound to a minimum
Ron your pics on post 31 pretty clearly show the neck-down restriction, pics 3 and 4.
If pic 4 is the rear muffler, the guts of that thing must be somewhere around 2.25". There's the source of your problem Unigroup identified.
Adrian the best/biggest mufflers may well have to be made, but there are decent off the shelf units around provided you look.
There's not much bling factor with Hurricane or Mercury products, but they offer sizes and shapes that can fit and provide decent flow and muffling ability.
Na Wolverine, I had a HKS cannon before, got rid of it, I much like my quiet oval, just hope its not a restriction, Blackkers do you mind taking a pic up inside your muffler tip like I did above, I want to see how big your hole is cos mine looks small lol..
Do you guys not think my mid-muffler could be the culprit with that tapered 2.71inch exit at the back?
Oops your post didnt come through until after I posted, Dale, yehthe guts of that thing looks small aye :(.. I ordered a 3' oval xforce supplied n fitted by Western Mufflers in Fairfield coupla years ago and thought thats what I got, doesnt look like it now..wtf
  • Like 1
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
