Changing my OS Giken Quad to something a bit more forgiving as a DD.
The car is 338 AWKW and I do not expect to take it past 370 AWKW with the work I am having done soon , the quad is over kill for this HP.
Been looking at 2 types, Nismo C-spec twin copper mix and ATS Pro-Spec single , Carbon on carbon type, I think this is the model?
Any feedback or suggestions welcome before I have to confirm the work .
Nismo c spec.
Been in my car for 9 years, 40,000 kms, over 300 launches currently holding 472 rwkw. Good enough to fark up an OS GIKEN 5 speed. Lovely to drive.
Ordered yet? Lol
Fixed, :D
I have Exedy twin in my 32 which runs 11.1, has been there for 8 years of massive abuse and still going
Nismo twin was an Exedy twin
plenty of great clutches to get you there and hold for a long time.
Im currently running a OS giken TCS2B twin plate.. has the cool rattly twin plate sound, is ever so slightly heavier than the nismo twin pedal wise but thats because the nismo twin is too light for my tastes
Im also a big fan of the ATS carbon twin/triple plate as they both have a great pedal feel and progressive bite for daily duties.
These are both Puk style clutches where piggies Nismo is a full face organic disc.
Hope someone can understand my next question
I am changing my turbo from a T78 to a PT6262 and installing Poncams Bs, I wanted more power down low as it is a DD, the mechanic said it will spool much earlier and I will have a bit more torque down low.
I only have a problem on steep hill starts at times if I do not get it right , if ride it a little with the revs around 3k it is OK BUT not much room for error. Will this extra torque and earlier power from the new set up stop that lag when the clutch engages, even when ridding it, it lags.
Not sure if LAG is the right way to explain it, it feels like the revs die even if you are still trying to build them as the clutch engages?
I have not ordered anything yet but only have a short time before getting the other work done and have to make my mind up very soon.
Seems the C-Spec and the ATS carbon are both good choices and cannot go too far wrong with either of them.
Thanks for your collective help every time I need it :yes:
  • 1 month later...
Hi Dave
Had the Turbo and Cams changed and the car ran great, the clutch was soooo much easier with a bit more low down power, a different car , you could feel it working like a car should not a heap of crap.
The brown is the new tune :yes:
I was really happy for 300Klms and lost the bloody tune :angry:
So have to start all over again, going to change the ECU , maybe Haltech or MoTech , do you know anything about them or recommend another brand for me to look into? :action-smiley-069:
Motec is over kill on a street car and costs a fortune to unlock every single option on them
Haltec will do everything you want and so will a few others, link is a good choice for the fact it goes into the original ecu case and looks factory
As long as they don't lock the ecu (password it) then as long as you have the correct software then you can't save it to your laptop
So if they do not lock it up with a password I can use the tune or whatever is put into the ECU?
Then you say if I have the correct password I CANNOT save it to my laptop, was this a TYPO ?
As I said, I am learning :)
Nismo c spec.
Been in my car for 9 years, 40,000 kms, over 300 launches currently holding 472 rwkw. Good enough to just an OS GIKEN 5 speed. Lovely to drive.
Ordered yet? Lol
Just drove back from Sydney after the mods and with some power down low it is easy to drive, I will see if I can post the new Dyno Tune
Yes sorry I meant to say you can save the tune to your laptop
I knew what you meant, I think I will get a cheap laptop to do only car stuff and not use it on the Internet as there are too many things that can stuff your computer up if you use the Internet, well I think so?
Afraid of the Internet? But on the Internet now! ;)
Not afraid of the Internet, just what it can let through to my computer and take a safer option , keep stuff that does not need the Internet away from it. :yes:
I have a seperate laptop for interweb banking and car tuning and another one for everything else, cause doesn't trust anything :D
Good thinking , I was going to use my laptop just for this but had to do a couple of OS trips and started using it for everything, now I cannot even log on to this Forum with my laptop (using PC now)and had to re register under a different name T R NISMO1 , so unless I have the shop clean it out I will get something else for banking and private info without going on other websites , paranoid , you bet :)
I clean 30 to 60 spams from my mailwasher every day, put them on my blacklist and spam list but they come again and again and it is bloody annoying :(
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
