Ok I got distracted and bought two more Defi gauges, oops.
The ones I got are exhaust temp and oil pressure.
I'm wondering if I should repurpose the oil pressure to show fuel pressure instead, given that the R34 has a factory oil pressure gauge already? Not sure of its accuracy though..
https://www.sau.com.au/forums/topic/441108-gauges/page/4/#findComment-7657169
The newer "OEM" ones from Kudos etc react instantly, so if you want to get your stock Oil pressure gauge to do something, replace the current sensor with a new stock sensor and you shall notice the difference.
  • Like 1
https://www.sau.com.au/forums/topic/441108-gauges/page/4/#findComment-7657369
  • 1 month later...
Any suggestions on where to mount them?
A Greddy (style) A-Pillar dual gauge pod might be an option but I'm not sure if it's a bit too much circus for my taste...
Finally got organised and installed the gauges, ended up putting them in front of the instrument cluster, see below.
Exhaust, water and oil temp in the triple gauge pod, oil pressure and boost in front of the steering wheel. It's a bit of a Christmas tree now but oh well.
  • What would be the normal operating range for exhaust temp, and where should I set the warning level?
  • Same for oil pressure, from memory my OEM gauge used to read somewhere around 4 but it's been disconnected for a little while..
Five Defi gauges in R34 GTT
Also since I couldn't find this anywhere online:
Getting cables through firewall grommet on driver's side in R34 GTT (remove wheel and rear guard liner to access)
https://www.sau.com.au/forums/topic/441108-gauges/page/4/#findComment-7673002
My Neo will cruise very lightly at ~450°C. Faster cruising or a little load will see 500-600°C. Moderate load will easily see over 700°C. High loads will go over 800°C, max on the gauge's memory is something like 950°C, but I reckon that got set during a boost/load cut when I was tuning the boost controller, because I don't think I've noticed anything over 900°C any other time. I think my alarm is set at 950 or so.
Oil pressure should idle in the region of 4 bar when cold, falling to maybe 2 bar when hot and rise to 6 bar or so at high revs.
https://www.sau.com.au/forums/topic/441108-gauges/page/4/#findComment-7673006
Exhaust temp depends on where you mount the sensor, it should be just before the turbo. If you mount it in the dump the temp will read approximately 100c less from my testing.
Awesome thanks guys, really helpful.
The EGT sensor is in the dump, just in front of the O2 sensor, so will read less than before the turbo.
https://www.sau.com.au/forums/topic/441108-gauges/page/4/#findComment-7673229
  • 1 month later...
For reference, here's the peak readings from Sunday's track day (ambient temp around 24C):
  • Exhaust 900 C (at dump)
  • Water 108 C
  • Oil 117 C
  • Oil pressure 6.0 bar
  • Boost 1.45 bar (should probably dial that back a little...)
This is after the oil cooler installation with virtually no cool down laps (short sessions though), the cooler made a big difference.
https://www.sau.com.au/forums/topic/441108-gauges/page/4/#findComment-7691658
What's the lowest you guys are reading for oil pressure? Mine's around 2 bar in normal driving but I have seen it drop down to around 1.2 bar when going from proper throttle to decel (clutch in). I'm guessing this is normal?
https://www.sau.com.au/forums/topic/441108-gauges/page/4/#findComment-7693072
ECU Engine protection functions > Gauges
Do the defi units have an auxillary 0-5v output?
You mean for the signal? I don't think so, all the signals go into the control unit and I believe the Defi Link daisy chain is a pretty basic serial bus that drives the stepper motors in the gauges.
The gauges do have an alarm output for an external light for when the set alarm level is reached.
https://www.sau.com.au/forums/topic/441108-gauges/page/4/#findComment-7693105
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
