after bit more info and feedback re: quaife rear diff on the gtr, anyone running one of these yet?
not sure if its directly swap jobbie, unlike nismo items that require half shafts etc
who here is running one?
already had great things about the front but for the rears not sure if its better than nismo 1.5 option
https://www.sau.com.au/forums/topic/441222-quaife-rear-diff/
Hey Nesh, to have a chat with Terry at Award about rebuilding your standard diff tighter, that's the easiest and most likely cheapest way for pretty much the same result
I don't know about the rear diff but the quaife front diff is a gear résistance limo and doesn't 100% full lock which is what makes it so good for the front where you want the back it to full lock on acceleration
  • Like 1
bought front quaife diff, was chatting with owner of jjr, he swapped from nismo 1.5 to quaife rear, said difference was chalk n cheese, few other 32 gtr including donut king r35 has it in the rear, no chatter unlike nismo, maintenance free, lifetime warranty etc
has me leaning towards the quaife rear
When doing my rear I was tossing up between the quaife and the Nismo GT pro. I went the Nismo because the Quaife in the rear was just released and there was no feedback around, despite how good it was up the front.
The Nismo, on medium is way too much, I need to back it off and to get back that front drive that the quaife gave prob need to throw some extra friction plates into the transfer case. The Nismo (Atleast on medium) is one agro mofo.
How the quaife would go as a rear, it won't be a bad thing, may be super special but there isn't many people running one as they are so new.
Go drive an R34 (GTR). Nothing new there. Helical is helical.
Michael, you have both cars, you notice any difference hopping from one car to the other
the other thing to suss out is if quaife requires half shafts like the nismo or other mods
Yeah, their two completely different cars to drive on the edge is stock form, as far as drive line is concerned that is, the 34 doesn't always spin both back tyres in the middle of a turn unless pushed very hard making it a bit unpredictable and then by the time you've got them spinning the front has kicked in already pulling you straight, the 32 is the oppersite, in a straight line the 34 has sooo much more initial grip, but most of that is the transfer case being preloaded in the 34
http://m.youtube.com/watch?v=WpQETVmmS7w
At 1.15mins is an example of me pushing hard enough then 5secs later me pushing a bit to hard
I haven't punted it yet with the quaife in the front fitted
I have a spare R32 diff and new R34 gearing which I'm going to but in the rebuilt 32 diff and then jam it in the 34
pretty much in the same situation as OP..
option 1: rebuilt kit for r200 (250$ + was told about 400$ to rebuilt/retight the diff) should be tighter but not overly tight as a Nismo GT. no worries about bolt-on
option 2: buy a quaife because maintenance free, less chatter, drive smoothly but would still like to know if it's bolt-on affair.
option3: Go for a carbon diff ( most likely used, seen some from 600-1000), heard they were smoother, less maintenance and drive smoother than regular metal lsd.
Well I have just purchased a quaife rear LSD.
Pretty certain it will need modification 'as early R32 cars will require the stronger later driveshaft flanges to use this' whatever that means.
correct, emailed Tim @ SVS and he confirmed using later model half shafts which are stronger as it has larger internal spine size, not a problem if your car is already late model 32 or 33/34 and non v-spec, straight bolt-on
Yes I just picked one up too... so I got the front and rear! In a R33 GTR however.
nice. When you did the front one how did that compare to standard setup?
The front one is right next to my foot still under my desk at work soon to be joined by the rear one! Slow build man, you will find out before me fortunately for you...
I think we got the last ones before the price rise too! :)
Lol I know that feeling having performance parts under the desk.
Yeah, that is BS re: price rise.
I really don't want to fork out almost $2K just for a diff when they are being sold for almost half that price in the states.
http://www.frsport.com/Quaife-QDF3L-ATB-Differential-Nissan-Skyline-GTR-R33-R34-front_p_29114.html
Just waiting upon some more diff bushes and new diff bearings and then will get it installed.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
