Nulon Nationals kick off on 6th of April at the famous Bulahdelah Hillclimb. Round 2 is on the 4th of July at Wakefield and Round 3 at Cootamundra airport
Thanks To Nulon they have invited SAUNSW to compete at the NULON Nationals, with a multicar Team against other clubs!
The Pulse Racing Evo and other Crazy Beasts will be competing at the event
Please go to their facebook page and like their page.
The link is provided below
https://www.facebook.com/nulonnationals
Bulahdelah Hillclimb 5-6 April 2014
Wakefield track day 4th July 2014
Cootamundra Airport drags 20th September 2014
The Team representing SAUNSW for the first round at the famous Bulahdelah Hillclimb is
Mat 34geeteetee
Steve Ka
Brian
Nick Adams
Duncan
JLM
Please show your support for these guys and NULON for putting on such great events
Edited by crashdown
https://www.sau.com.au/forums/topic/441342-nulon-nationals/
I'll have to make it up to Wakefield to see this!
You do man! And bring the crew with ya to support the SAU team :yes:
There is hundreds coming to the Hillclimb event apparently so its going to be epic!
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7245862
Thank you to NULON for their commitment and lubricants! :)
We wish our Nissans the very best!
Can't wait going to be epic fun!!!
Thanks Terry! And certainly thanks Nulon!
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7245977
sadly my car isn't ready (just too much to get done in the last few days), but Neil is a champ and threw me Cheryl's keys. So this is my pic for the weekend
See you guys up there, should be an interesting event
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7246118
What amazing depth of quality cars in our club!
(Except maybe that nugget GTT... Jks :P. )
Good luck guys, take it easy up there, live to race another day.
You motherf**** :P But yeah i still wanna get a Nugget Motorsports sticker :laugh:
And YES live to race another day is a good motto, it is fast and it is not a prepped surface -
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7246557
Those new tyres should be better than the RSRs if it is damp. Andrew and I will be driving up early on Sunday for a watch.
Hope so, steer tyres are still 255 RSR!
where was my invite to be part of the team! :P
Do you even have enough power to make it up the hill? :whistling:
https://www.sau.com.au/forums/topic/441342-nulon-nationals/#findComment-7246723
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
