Car: R34 GTT
Problem: TPS light, Skid light and Check engine light are on and car is running sluggish and idles a little higher then it should 1,200
I installed a friends stock R34 ECU into the car and it fixed all the problems and cleared all warnings idle returned to normal.
So what is wrong with my Power FC?
*Is it blown?
*Is there settings that can be changed to fix this?
*What was the cause?
Has any one experienced this problem before? I don't know what caused it but I just want to know how I can fix it.
I don't have a hand controller but can possibly get access to one.
Thanks in advance
Is it 2nd hand?
You may possibly have the wrong afm setting, this will cause some crazzy running conditions.
You really need a hand controller to see what all the settings are, and to see what all the feedbacks are doing.
The power fc was purchased and tuned for this car. I don't know what the previous owner had done tune wise or anything like that but the car has since been in storage over a year not really moving.
The slip and tc lights seem to be a common problem with the power fc. Someone asked similar questions not long ago. Had the tcs and slip light as well as the check engine lights on with the power fc but nothing with the stock ecu. Not sure if an answer was found
Given those three systems complaining at the same time, their most significant intersection with respect to the ECU is the TPS, and possibly the auxiliary throttle used by the TCS system. The other significant option affecting all of them is the vehicle speed sensor.
  • nicksamaniac: Thanks for your advice. I am trying to get hold of a hand controller as we speak.
I think I found the thread about it( http://www.skylinesaustralia.com/forums/topic/407575-tcsslip-light-on-with-pfc/ ) . I have messaged the guy to see if he had any luck fixing it so hopefully he will reply. On last look he had every signal symptom I am experiencing but no solution. He even had the car tuned and they couldn't figure out the cause of his problem.
Would the above mentioned such as speed sensor be affected all the time not just with the power
If you're asking me if the problem would be there all the time with any ECU or only with the PowerFC, then my suggestion would have to be that I would be looking to the PowerFC as being the problem. TPS for example is something that has a threshold setting to set idle (for example) and the threshold could easily be different between a PowerFC and a stock ECU. The VSS comes from the speedo head to the ECU and is then passed to the other control units (HICAS, ABS, TCS, etc) and if the PowerFC has a different pullup resistor behaviour or something then it might interfere with the way that the other control units see the signal. There are all sorts of things that can go wrong, and to a certain extent, good luck trying to figure it out!
If it were me tuning an R34 (and it is, I have a Neo transplanted into my car) then I would use a Nistuned factory ECU over a PowerFC simply because of these seemingly random problems that the PowerFCs seem to cause. You take a bit of a hit in how hard it can be to tune a Nistuned Neo ECU (they're not as simple as older ECUs or PowerFCs)....but they work like the original ECU does because they ARE the original ECU.
GTSBoy: I appreciate your input and to correct my self in my previous message to you I forgot to finish my sentience it was suppose to say Power Fc but I am sure you understood me.
So because I have checked over the car plugs top to bottom and with the fact that the stock ECU is having no issues I can conclude that connections should be good.
I would love to solve this problem by just purchasing the Nistune how ever this is the ECU that has been tuned and for the moment at least its all I have got.
From reading the other post and talking to tuners I have come to the conclusion that this is not something that will be fixed by a tune or a setting with the exception of the check engine light.
* Is it possible spark plugs are causing this problem? i checked the coil packs and they are all fine so I replaced the spark plugs with what was already in there .7 could this be the problem? Because the power FC is tuned to much higher power.
*Fuses I am pretty sure I have checked the car over for blown fuses but maybe I should double check some people say that power FC can only run on a specific current and a blown fuse can disrupt this?
* Active LSD people with R33's say there is a problem with the power fc going funny after time recognising the active LSD and it plays up I am not sure if I am experiencing this and have not read any where of R34's having this problem.
*Could a damage piece of suspension cause this error?
Any additional advice is welcome thank you all
Edited by Rps13
Due to having a PFC you can't have the system diagnosed with a consult unit, so you are stuck diagnosing it manually. Not much we can do from here.
If with the stock ecu everything is working, I can't see it being an external sensor fault... It is inside the PFC.
Do you have the hand controller for the Power FC? If so you can check a few things like how your TPS is behaving and if you have any sensor or switch problems
From memory the other person experiencing these issues had no problems but with the sensors etc. Not sure if TPS voltage might be too low on closed throttle, should be about .45V - .55V from memory
Surely it isn't a problem with Power FC's in general if they are made for the 34, which all came with T/C (I think?)
Could spark plugs be the problem? I know in some strange way most problems like this come back to spark/coil packs. Now I know my coil packs are fine but when I changed the spark plugs I replaced them with the same ones that were in there and they had a .7 gap. I was reading some where that with more power you need a larger gap.
My theory is that the power Fc should be tuned for around 240kw and when the stock computer is in because it is running standard power no codes are thrown so when I plug in the power fc and it requires larger gapped spark plugs?
I don't know and can't find much information on the symptoms of running spark plugs that are too small in a R34 but as I am clutching at straws it seemed quite logical approach.
No, not suggesting it is a problem with all PFCs. But would strongly suspect that in this case the PFC is where the problem is occurring. They're just electronics, like any other ECU. Something is always ready to go wrong.
Yeah all good, I just wonder why there is the odd Power FC for 34 that seems to have this issue, but it cant be too much of an issue or the forum would be littered with threads about it and alot more answers.
Not sure what the go is, but if the stock computer works fine and the Power FC doesnt, it seems very likely that there is a problem with that specific Power FC
And spark plug gaps, as said, dont make any difference at all. They may make a difference in power output, but wont log faults etc
  • Like 1
I know what you guys are saying I just feel like i am chasing a needle in a haystack. Clearly something is wrong with the ECU but people have had no luck fixing it with the hand controller or playing with settings with a computer or tuning. So the only thing i can think of is something that the power fc might be over sensitive to or is having trouble interacting with due to the power of the tune. Clearly it's not a plug or something that is broken. I just don't know where to go from here with this problem.
Previous people haven't found a solution so while it is a rear problem the solution eludes us all for the moment.
It's probably the same PFC being handed around over the years with similar problems on every owners cars. :P
My suggestion is to lash out a few hundred extra on the Adaptronic, or Haltech/Link if you have the coin. PFC is old tech.
I'd suggest contacting apexi support and seeing if they can shed any light on it. Otherwise finding someone who can actually check/repair any circuitry that might be wrong with it (not quite so easy)
  • Like 1
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
