Nismo 740s are 16600-RR544
Looks like you might have "Jecs" injectors which are OEM or copied Jecs injectors remanufactured to different flow rates.
These have a poor reputation so will be interesting to see how they bear up in testing (and in tuning).
score! don't forget to get the lag times....you'll need them when for when you tune.....I'd advise you to put them straight in after the cleaning and flowing as mine got stuck after not putting them in after a full bench flow and test and multiple ultrasonic baths...I only waited 2 months.
I'm running some of those remanufactured 850s from tlf performance. it goes on the dyno tomorrow....hoping for the best.
You just can't explain it to some people Ben, the extra time required to set the idle on the dyno, mucking around with lag times to get them feeling good, the hassle is, there is no way to know if they are all similar.
Remanufactured means some company took your stock injectors, ran a drill through them, cleaned them then sold them back for more than a new set of Xspurts would cost. I just don't get it...
they idle fine if you get your lag time right in your corrections....thats why its important to know.....and i get about 400+km to a tank. i'm pretty pleased i didn't piss $1000 up against the wall when there are injectors out there that will do the job for a third the price.
Badgaz, a shit spray pattern is still a shit pattern. And compared to modern injectors the pattern of drilled injectors is terrible.
Maybe you get away with it for around 700cc or less but bigger than that idle is way harder to get nice, and economy will suffer. If you compared to decent injectors you would realise straight away.
You do however get an acceptable result with drilled injectors if you don't know any better though. They will make same power on a dyno and that seems to be the only thing people care about.
A good tuner doesn't need lag time guesses from the manufacturer, they work it out initially during the first part of the tune. The problem comes when there are differences between each injector's lag time, as there is no way the tuner can compensate or even know.
If you are paying 1k for injectors you are getting ripped. I can sell Xspurt 1000's for $600. Top feed rails are $100 from Goodies direct... The Nismo's are closer to that 1k price, only due to the name.
yes agreed there is the theoretical world and the real world...my lag values had a correction of 0.29 at 14volts from the manufacturer....it idled a little crappy and i adjusted the correction to 0.31 and it idles perfect....just like they were suppose to be 850's but i'm working off a correction factor that is 52% which puts them around 750cc. 1k is what we'd pay over here in NZ for a set of 740's.
You can get IDs for less but I'll just get my next set of injectors off Scotty.
Just to close this thread out, picked them up today. They have been drilled/flowed what ever they are!! Flow ended up being 800, well 790mil. So enough for what i need. Pritty happy to be honest. The guy that gave them a service replaced all the O rings etc and said the spray pattern was spot on
Fair enough, spot on was my wording. He said they had a good consistent spray pattern. Translate that into injector service technician speak and you have the correct wording
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
