http://page14.auctions.yahoo.co.jp/jp/auction/s468871332
found complete one off turbo kit from japan doubt instructions are included
"The mounting requires cutting of reinforcement. " Im going to assume that'd be more trouble than its worth
Meh, I carved great chunks out of my FRP reo to fit a radiator; its the Stagea way.
If you don't need to cut anything; you're not trying hard enough.
  • Like 2
Review Hypergear SS2-M35
If you are not willing to run E85, aftermarket ECU, upgraded FMIC, brake wire mod, big exhaust(from dump back), big intake pipe(3"), big injectors, kitted transmission, big fuel pump, no cat convertor, modded BOV: ==>DO NOT RUN THIS TURBO<==
Without "all" of the above mods the car is an absolute pig to drive below 4000rpm and part throttle. Even with the above mods this turbo will not make 20psi by 3700 as advertised(that was on an Rb25 with different housings and is misleading advertising)...however it will with all mods start to make "some" boost below 4000rpm which makes it bearable in everyday traffic. Is the trade off worth it for the power output ?...no not at all, the problem is package constraints so we are very limited by choice if we want an easier fitment. The only place this turbo would be faster than the smaller high flow is acceleration from 50km/h or higher. A Garrett 3071 or Borg Warner 6258 or 6758 are much better options for average power "if" you are willing to make them fit. I was told on purchase that the SS2-M35 would be reasonably responsive then to be told on delivery it's response would equal a 3076 .82 with the power of close to a 3071 .6 which I would agree with.
Matt
Edited by BoostdR
  • Like 2
The higher stall convertor is a band aid solution. I would rather fix the problem rather than the symptom. I don't even think it would slip enough for this turbo whilst still being streetable(shaft speed differential for lock-up)
If you are not willing to run E85, aftermarket ECU, upgraded FMIC, big exhaust(from dump back), big intake pipe(3"), big injectors, kitted transmission, big fuel pump, no cat convertor, modded BOV: ==>DO NOT RUN THIS TURBO<==
Matt
Interesting. what Kw are you getting with your stagea, if you don't mind me asking? im going to try my luck with a HX35/2, We shall see what happens lol.
looks like the Holset HX35 has decent Surge resistance I wonder if that is with the anti-surge comp cover which will reduce efficiency up top slightly. There are many factors which will make or break the response. I've seen mixed results.
I don't have a solid figure for the SS2 yet. Giving It the best chance to perform I can. I'll post up results once I've exhausted its flow capacity. I expect 270-300kw
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
