Currently running 16.8 degrees timing in 3rd gear. I increased timing by 5 degrees this morning and it was considerably quicker. Smoking all 4 tyres on accel.
My concern is however the timing is gear specific as controlled by the OEM ECU. Increasing the timing that suits 3rd will cause huge timing figures in the lower gears...possibly explaining why Tao's M35 exploded in 2nd gear at part throttle.
There is a speed vs fuel map in the EMU however no speed vs timing. I might look at translating speed to a 0-5v signal to utilize the temp vs timing map in the EMU since the OEM ECU handles that anyway.
There is no question we have more power to be extracted. I just want to be smart about how it is controlled.
What's 1300lb torque in NM? I tried an online conversion tool and it gave me the result of 1700NM!
I have no idea what formula you used.. but I'm going out on a limb to say its incorrect. TE = T*R*1000/r I dont know the gear ratios, diff ratios, or rolling radius of Matts tyres so it'd all be a stab in the dark.
Dyno sheets are just a tuning tool, I'm looking forward to it having a run at AIR and seeing what numbers it can put down!
Agreed it's a weird figure that's at the rear wheels. Makes no sense and is definitely not 1700nm and a reference-able figure. Good for highlighting the torque curve only. It's certainly making decent torque. I just need to connect the rpm trigger on the dyno next time to get a normal type of output. Will do this when I get around to actually tuning the timing. Only running 16.9 degrees ATM.
Keen for AIR also. Need to fix the damage from it coming off the dyno first.
Edited by BoostdR
I realized its a tuning tool, it was out of curiosity to see what the VQ makes vs the B5 Audi S4 2.7ltr twin turbo.
Torque figures on roller dynos are usually pretty inaccurate from a numerical perspective (perhaps they can be accurate with correct information input). my pulsar has made anything from 600 to 1000NM's lol
Yea you need the info that Dunc mentioned above to accurately work out the torque. I think what is displayed on the dyno is tractive effort or some crap which then needs to be converted using the ratios etc as Dunc mentioned
Are there options for me if i simply want to upgrade core to one with a steel turbine rather than ceramic ? I have not seen it pop up at all and it is an upgrade in terms of material used
like a hi-flow?
http://www.hypergearturbos.com/index.php?route=product/product&product_id=79&search=m35
I'm not aware of a direct fit steel wheel replacement. Of note. If you fitted a direct fit steel turbine you would go backwards in terms of torque(low end response) there are small high flows available now which respond very similar to stock.
What are their wheels made of? Are they just a Garrett core with our housings or something else?
I think that's what stripey wanted, just a basic high flow that will respond similarly to stock but without the concern of the ceramic wheel.
Yes you can get a Garrett core replacement. Original replacement with the ceramic turbine has steel ball bearings and the newer Garrett cores are Ceramic Ball bearing with inconel turbines. As long as the rebuilt unit is ball bearing or CBB you will claw back some of the benefits of the ceramic turbine.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
