Yeah will find out. I think you should vent the BOV to atmo. There is atleast 1k RPM in response. and an extra 200kw
already is.
lololololztutututututututututututu.
I have a couple of Pure JDM HKS ones that vent to atmos that were loud as fk on my gtr.
Like these:
But srsly Plumb it back properly bruh
lol, there is nothing there to plumb it back too mate. at all. maybe if someone coughed up a gtr bov, i could get scotty to weld someting up.
I'm sure someone in vic will have a stock BOV floating around?
Those HKS ones are loud as f**k. Twas great.
I don't has Stock ones spare as i went back to stock to make motor run betterererer
It's possibly the cooler is too big. What about running like a 200sx cooler or stock r33 gts-t cooler? something smaller? That's a question for someone that really knows what they are talking about
Dump should make quite a bit of difference.
EVO 6-9 intercooler would be best :yes:
going by the size of them mick i dont think it would make that much difference!!!!!!!! but its something i can look into at a later date.
right i started pulling it down last night. turbo, cooler, dump and manifold off.
gotta check all the timing marks are in the right place and take the chain off. then cams out and head off. excited too see what state a 300km engine is in......
dump pipe is so obviously a restriction its mad. its f**king tiny and must be destroyed. cue scotty and a custom one.
or does anyone have one r33 gtr dump pipe aftermarket available?!
just a quick recap of parts,
custom front pipe 2.5 inch to cat, 2 inch to VAG diesel muffler built by scotty. thanks!
stock gtr 33 dump and turbo. thanks grant for supplying!
custom cheapo ebay knock off hks filter that bolts straight to the turbo. thanks ebay!
custom very short cooler piping. cheers scotty.
ford xr6t intercooler again scotty with some help from alvin
stagea/r34 370cc injectors. you guessed it, scotty!
r33 gtr fuel pump thanks greg!
custom made knive edge steampipe manifold thanks scotty
soon to be jdm plastic rocker cover, micra
arp studs, usa. actually from a ford escort....
ga15 throttle body and afm, my mate in NZ
sr20 oil filter re locator modified to fit cg13, with un regulated oil cooler.
nistune'd by dmd tuning on e85. thanks david
jun 4.2kg flywheel (10kg lighter) micra forum.
exedy heavy duty clutch. same
bc coilovers front, kyb shocks rear with tein springs not telling.
nismo rear sway bar, whiteline pan hard rod. micra forum for sway and me dad for xmas for the rod!
rear disc brake axle conversion. harveys wreckers in langwarrin. great blokes.
front n14sss brakes with hel braided lines, rda slotted and dimpled rotors and qfm a1rm pads. brakes from wreck, lines rotors and pads supplied by jason at garage 9. thanks!
super s front bumper. harveys langwarrin.
n14sss/gtir wheels wreck.
suziki swift ver3 recaro front seats, tony tran, thanks man.
n13 pulsar steering wheel. wreck.
i think thats about it!
thanks to dave as well for coming and being my eyes the night before roady when i couldnt f**king function any more.
if ive missed anyone, please chirp up its been that long and ive had that many parts from you all i cant remember!
one last thing, scotty is a mate, but 90% of the things he supplied and built where paid for. he is a buisness after all! the other ten percent was bourbon, jerky and foaming hand shandies.
Good list of parts mate. Whats the filter element like in your Pod filter? That could also be restricting you a little bit?
Get us the dyno chart reading when it next goes up!?
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
