I think both sides (talking globally here; not talking about people in this thread) have an arrogance that pisses each other off.
Cyclists that flaunt themselves on the road, taking liberties just to piss people off, and motorists that think the world revolves around them (ahem mums on the school run....) and nothing should ever get in their way.
Sounds to me like Daleo is a good example of a responsible cyclist, he isn't going to be the one taking up a whole lane on a single lane road, he'll wave you past when it's safe to do so. In turn, and in respect of that, I'd pass him giving him as much room as I safely can. That's all that needs to happen.
  • Like 2
this.
and when I ride, I keep to the opposite side, so I can see on coming traffic.
I ride on the road(when no brake down/bike lanes are available), and move onto the mud/grass/gravel when a car does approach.
I want to see them coming.
that way, I can react accordingly.
I also dont wear a helmet (lets not get into that debate atm), and have never been booked for not.
but...
if I do get booked, my reaction will be taking an entire lane the entire trip.
because, thats the law....
dont ride much anymore, so doubt it will ever happen.
aaand, go...
this.
but...
aaand, go...
How is your crank bearing....?
Here's an interesting article from the US about the "Idaho Stop".
http://www.vox.com/2014/5/9/5691098/why-cyclists-should-be-able-to-roll-through-stop-signs-and-ride
It proposes some constructive solutions for getting bicycles off high traffic thoroughfares, which would be a win for both sides of the argument.
Not trying to inflame the situation, but there is some useful info in there, and the rule (or a version of it under a different name) has been in use in states across the US with fewer negative outcomes than the status quo.
Yeah, apparently cars are exempt from the laws of physics. Spot that line in there?
Frankly, I didn't think it was a very well written article, and it didn't sway my opinion that it is safer to have enforced stop and red lights.
If governments were serious about reducing carbon emissions, they wouldn't be installing traffic calming devices, red lights etc etc all the time. Imagine the carbon footprint of a new set of traffic lights over its lifetime?!
But that's ok, cause the government gets the cash from the fuel excise.... :/
Did you see the main point in there? Bicycles don't trigger the light circuit, so the lights will never change. I am sure many of the motorcyclists amongst us have blown a red for that very reason. I know I have had to many times over the years. Does this make me a criminal worthy of being stoned with spark plugs? Farkin wanker...
"Several states have similar "Dead Red" laws, which lets cyclists (and motorcyclists) ride through a red light if there's no traffic, if the cyclists have stopped for set periods of time, and if the light isn't changing because its sensor doesn't register bikes."
Yes, I can see that, after stopping for a set amount of time, the cyclist can proceed through the intersection. They might also be able to use that magical button on the side of most traffic lights that turns them red to allow people to cross... ;)
Anyway, thanks, when did I ever say I chuck plugs at cyclists....? I thought my posts were pretty neutral....
Wanker comment was directed at the bloke suggesting it.
Cyclists aren't allowed on the footpath, and quite often are clipped into their pedals. Magical button? It's for pedestrians. Yet again, there are no facilities for cyclists in most cases. These would need to be included in any bike rego process.
Carry a broom stick to push said button? :P
Then you can bash arsehole drivers who try to clip you, and also have a jousting session when you get to two lane bike paths! :D
  • Like 2
Bicycle jousting is the best solution this thread has produced.
Nice work Luke!
Brb, off to get a broomstick.
It wasn't saying that cars expend no energy to get moving from a standstill, just that the driver isn't the one physically getting the car moving again; unlike the bicycle.
Nice work Luke!
twasnt my idea, but I like it.
You shall be forced to mount the toddler tricycle for the first round of bicycle jousting.
Mmm K?
Nay, I shall be astride the toddlers balance bike.
Yea verily; it has newfangled yellow plastic wheels, and an ooga horn.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
