hi everyone i am having a problem atm with my r33 gtst rb25det it has been a problem since i have owned the car even after i have swapped motors.
when warm or cold as coming onto wot the car surges from 2000rpm to about 5000rpm then after that it completely frees up.
its a bad surge and if i hold wot when it surges it back fires and sounds like there's a front fire ?
standard boost well standard setup,
has front mount.
i have got new plugs gapped at .8
and have swapped coil packs no difference at all
timing is at 15 degres and the more timing i give better it gets
also has a new walbro hp fuel pump cant remember what models was good for 300 hp tho.
but when car is running or fuel pump is primed the fuel line isnt hard hard i can push it half way in .
any ideas on what it is guys all help much appreciated ??? thanks for reading :)
https://www.sau.com.au/forums/topic/443331-r33-gtst-rb25det-surging-help/
Checking the hardness of the fuel line won't tell you anything, that's what a fuel pressure gauge is for.
Obvious things to do are clean afm and check for boost leaks.
Aren't you the guy with the rb20 turbo that glows red all the time, drives hard everywhere and just got car out of impound?
If you are at all concerned about low fuel pressure......then why not either install a fuel pressure gauge into the line or take it to a mechanic who can so you can see if there's a problem or not?
yes that is me. i have started to drive normal now thanks to the new hoon laws i just want car to run good thats all
y
Are you sure you checked the timing right? Did it with a plug lead between cyl 1 spark plug and coilpack and then put a timing light on
Sounds like timing to me, especially if it gets better as you advance it
Is the CAS dead?
Of course I would agree it could possibly be the afm as I already suggested that.
and also i took the rod off the actuator and its runs smooth as f**k obviously no boost ? so what do u suggest there? i have put a afm and borrowed a cas still the same ?
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
