It's been done before, I'm sure. Have a search on here, I know at least one person has looked into it before. From memory the R34 6speed needs a custom length tailshaft made up, and there might be a bit more custom work.
Gearbox mounts will be different - prop shaft will need work - you will need the ECU AND internal wiring loom that plugs into ECU , and the under bonnet wiring loom from R34 GTR as there are pin differences ! , the ECU from 34GTR will not fit Stagea ECU plug , GTR is blue plug and Stagea grey - you will need a bigger fuel pump - AND YOU WILL NEED BETTER BRAKES !!! MY GTR BRAKES WITH PROJECTMU PADS ARE STILL NOT ENOUGH !!
Here in UK we have a V8 Stagea - a 2.8 HKS stroker and a stock gearboxed 500BHP RB25DET - + some Autec`s
Its all been done before XCEPT 6 speed as far as i know ...
Thank you very much!
Big project...A lot of work need to do, if put the GTR engine in stagea.
I though just change the engine and Gearbox + some more.
The 6 speed is easy, but why would you want to get rid of VCT? You need every bit of response you can get in these heavy wagons. The RB25neo is a better engine overall.
Did you mean Rb25neo change the 5 speed greabox to 6 speed??
RB owners will not be impressed with the fitting of a 26 in a stagea ! , as stated the NEO25 is a far superior engine when tuned - fitting twin turbo`s and a 6 speed gearbox is worth a silent nod !
a rear wheel drive stagea with over 250whp that can be driven in the wet and not crashed would also be impressive
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
