Hey :)
I just bought another Skyline- an R33 Series 2 Mspec manual for very cheap (even suspiciously too cheap) due to un ergo, hole in exhaust (came with new full stainless steel one), misfire at boost problem which they said prob coil packs and interior dash lights and indicators don't work. Picked it up tonight and of course as was cheap I figured there will be a fair few problems I would need to sort out which is of course to be expected.
Drives great except splutters and chokes itself under boost. So far all the intake pipes and throttle body are absolutely filthy and it stinks like contaminated oil where the throttle body connects and the a lot of the hoses are bad and cracking which is all fine I can deal with that but what worries me is this-
Every single spark plug hole has heaps of brown sludge and water in there :( a decent amount as well! The coil packs look like ass so of course will replace those and the spark plugs. Firstly, what is the best way to get the water and crap out before I pull the plugs? And does the sludge and crap sound like a head gasket??? Please tell me there is something else it could be!
I will take some pics soon! Any help would be greatly appreciated!
Thanks
Em
I pulled the spark plugs and there is no water or oil or anything down there so that's good right? It seems like water accumulated on top as there was mouse crap too and a cockroach leg lol but yeah nothing under spark plugs
Clean up the entire engine bay and vehicle. Have a really good look over it, - Decide if it is worth spending effort and money on
Are the chassis rails straight, any rust, steering components, tyre wear, brakes, oil/water/air leaks, lights
What info did the previous owner give you?
Have you done a fast and revs check?
If keeping
Give it a major service including a good engine flush (Liquid Molly or Wurths). All fluids, plugs, filters
Did you get any service records with it? When were the belts done including timing belt
then go through and list all the remaining obvious issues standing still, then take it for a drive and list any running issues. get an idea of parts and prices (does it scare you?)
if not attack them methodically/logically
What aftermarket mods including ECU?
For the In cabin, dash lights and indicators - verify all fuses and relays
Sludge is from leaking covers and water laying around
Being a 96 33 GTS-t I expect your young and your budget is minimal
As you said there is a reason some cars are cheap.
Some times you can get a gem that just hasn't been maintained
Edited by Sinista32
Hey Sinista,
Thanks for the info! Haha yes student at the moment so relatively tight budget but all my money ends up going on the cars so if it needs to be fixed it will usually be done!
Have a service history with log book etc it came over from NSW so have the dates for belt etc. Chassis is nice and straight surprisingly minimal rust it's quite clean.
I managed to replace spark plugs but its going to need new coil packs considering they were submerged in water and muck. I use liquid moly on all my cars so will be putting some of that through. I don't like the BOV I want to remove that for now and just put it back to stock as will need it for pits anyway. Ran OBD no codes which is boring, other parameters seem good but not relying on that!
Coolant system seems good but will flush anyway, oil looks good etc. the car was sitting for about a year only driven every month or so.
Mods are basic just the crappy rusty looking blitz BOV, boost tee (not a fan will be removing that), HKS rear muffler, cusco strut braces, apexi air intake, aftermarket suspension- mainly cosmetic.
Since cleaning throttle body and pipes the car will start straight away idle for a second and die. Going to have to see if I put a hose on the wrong way or something- could mega vac leaks cause that?? A lot of the hoses are suspicious!! I will take some photos now of how the BOV and boost tee have been set up its all weird to me as my other one was completely stock.
Sludge around the spark plugs simply means it's had an engine degrease by someone who was rather happy with the hose. This has screwed the plugs and coils. New coils and plugs and it will probably run well.
Exactly what I was thinking. Quite possibly had the valley cover off while cleaning and have since put it back on.
Does look pretty nice for a cheap one, series 2 as well so if its just coilpacks and plugs that need replacing id be more than happy with that
Thanks :) I reckon she is pretty hot it's worth more but he had too many cars and a newborn so he just needed it gone. Good thinking guys! I found out it was actually a degrease! Why wouldn't u cover up that area though?
It's driving so much better and haven't even replaced coil packs or exhaust yet!
lol scotty yeah I want to get rid of it, don't want to really waste a tune on it. I figure I will have the work out which wires have been spliced or cut and put them back into my stock ecu? ugh annoying
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
