I have Wiseco RB25 pistons in a 30 block with a 26 head at 9.53:1 static comp ( +/- 170psi ) and have pumped 28psi into it on E80 before the rear housing choked it, going to change turbos later this year and keep pumping boost into it :D
Go for 9.5:1 if you plan on E85
  • Like 1
for those people reusing stock bottom ends, have you measured the bores on the blocks? what bore size have you encountered? Wondering what the acceptable piston to bore clearance has been and weather you've had any piston slap, cause i hate piston slap and want to avoid it.
will be taking the head off my purchased rb30 and want to know what bore size is acceptable and whats a shithouse result, im assuming more than a 3thou piston bore clearance is getting unacceptable.. my old man says that the pistons will wear more
than the bore.. is this right?
sorry if this has been covered but is it ok to bolt the head on with new head gasket and do a comp test to check the ratio
and then strip and reuse the head gasket? im assuming if i got like 150psi id take it off and shave head a thou or two then
bolt it back on to get my 9.5.. but hopefully it would be up at the 170psi the first time..
Edited by AngryRB
Mine was a fresh untouched 86mm, I went 86.5mm and decked the block to 0 deck height
Piston clearance is up to the manufacture recommendation, no deers eyes what mine is set to
Doing a comp test might give you an idea of the dynamic comp ratio but the static ratio has the be measured and calculated
I guess you could compare a motor with the same head and cams if they are both timed spot on.
too many factors would make it unreliable but it could give you an idea.
I should get skyrine to do a full comp test of his fresh motor once it's finished seeing as we have the same spec ideas.
Actually if you're reading this Skyrine can you tell me which head gasket you used?
I've read that the factory HG is 1.3mm can someone confirm that? Cheers
so no ones measured the bore of there block to see if its worn? i guess ill just check a vl commodore manual then and compare, just
wondering what people have done and how much the clearance was. My au falcon has 200psi each cylinder and there supposed to be 9.6
if i have that right, so with the rb2530 im thinking that's a good guideline??? maybe someone has done a comp test and knows what it
should be with 9.5??
I measured my virgin bore RB30 block and they were 86mm+/- .1mm Also it is my understanding (happy to be corrected) that your pistons rings will wear much faster than the engine block.
I am using a 1.3mm (.051 thou) cometic MLS as that is the standard headgasket size. I have had approximately .008 thou taken off the head from skimming when I got the VCT jacket welded.
If someone can point me in the right direction on how to calculate static CR I will do it, and I will comp test it when it's all assembled :)
Unfortunately I am not near the car until mid July, so don't hold your breath :(
My Tomei metal head gasket has been on and off 3 times now no problem. Not so sure about other types.
The calculation is the easy part - the measurement is the hard part. Here's a guide:
https://www.rbracing-rsr.com/compstaticcalc.html
static%20compression%20ratio%20calculator.xlsx
This is the one I created to roughly calculate mine...forget about some of the information there.
Obviously key in your inputs and it should spit out a number for the static CR....
Edited by R32Abuser
have been thinking about building a 10.5-11;1 CR rb30, would be mint for response and e85 loves compression. i'd use a 1.06 rear housing also to free up the turbine side.
but then i just go why bother, my stocker 30e with 26 head just works so well, revs to 7400 and takes 25 psi boost, loves it
Would you say the rb30 piston is stronger than an rb25 piston? does anyone know if the ring landings are the same thickness, ive heard the 25 is prone to failure
Im thinking of using RB25 pistons and decking the block, cause my block is worn.
Edited by AngryRB
a quick google suggests that 0.1mm is 4thou? so will you be happy with that much clearance?
How i remember it is 40 thou is 1mm so your correct in saying 0.1mm is 4 thou or 1/10th of 1mm.
As much as I would really love to see it done Simon, it's a dedicated drift car, responses is but a clutch kick away.
rips run mid 7.5 comp to 8.0 on there rb26/30.
low comp wont have any problems spooling up / lag
over 9.0 will cause many issues
including head lifting
A dedicated drag car can't be followed too closely when building a track car.
Higher comp won't lift a head. Or cause any issues. Especially on e85.
You are on your own with the low comp advice in this thread!
Edited by Ben C34
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
