Recommended Static Cr Target For Full Time E85 Street Car.
I'm wanting to replace the pipe joiners on my RB25DET. Anyone know where to find appropriate sized silicone segments. (tried Autobarn, but they are too short). Also, the joiner from the crossover to the first pipe is a slight reduction. And one of the others is a 30deg bend (most appear to be 45s). TIA
Where is this boost of 15-20 psi that you speak off. Surely not in the turbo inlet. You're more at risk of something being sucked in! I started typing "40mm rubber" into google and the 8th or 9th suggestion down the popup list was "cap", which yields this hit page https://www.google.com/search?q=40mm+rubber+cap&sca_esv=f17a4364060591de&source=hp&ei=rD1qZvC8Aq7vseMPoPmJuAw&iflsig=AL9hbdgAAAAAZmpLvAb3yMtgJDfUlLaPWSQoYci6lDgU&oq=40mm+rubber+&gs_lp=Egdnd3Mtd2l6Igw0MG1tIHJ1YmJlciAqAggIMgUQABiABDIFEAAYgAQyBRAAGIAEMgUQABiABDIFEAAYgAQyBRAAGIAEMgUQABiABDIFEAAYgAQyBRAAGIAEMgUQABiABEi9RVAAWOENcAB4AJABAJgBzgGgAbURqgEGMC4xMS4xuAEByAEA-AEBmAIMoAKrEsICCxAAGIAEGLEDGIMBwgIIEAAYgAQYsQOYAwCSBwYwLjEwLjKgB646&sclient=gws-wiz
https://frenchysperformancegarage.com/collections/brackets-and-ecu-mounts/products/ecu-mounting-plate-nissan-skyline-r32-r33-r34 just putting this out there
QFT Seems I provided sage advice. Glad your problem/s are sorted.
Practical solution...
